Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st April 2010, 05:02 PM   #1
Default Replacing CD Player power supply caps
Dear all,
I'm interested to replace the Yageo brand on my Burmester 061 with Black Gate ones. As I don't have much knowledge in electronics and I'm just wondering whether or not I could replace 4700uf 25V with 4700uf 35V or 50V, cos BG don't have cap in 4700uf 25V. I'm assuming that part of the circuit is voltage regulated and does that mean whatever value I replace the original with as long as I keep the same capacitance value I'd be fine?- Thx
Old 1st April 2010, 06:24 PM   #2
That's correct. With electrolytic capacitors, it's not a good idea to change the voltage rating by a large amount. So I suggest the 35V replacement.
Old 1st April 2010, 06:46 PM   #3
trd1587 is offline trd1587  Canada
trd1587's Avatar
Yeah and going upwards in Voltage migh also means thicker insulation then bigger in size.
Old 2nd April 2010, 06:31 AM   #4
Mooly's Avatar
Didn't Rubycon cease production of BG's around 2006 ?
How "old" are your new BG's
A simulation free zone. Design it, build it, test it.
Old 14th April 2010, 01:28 AM   #5
Andersonix's Avatar
While you have the pcb out, replace the ps diodes for soft recovery type.
I'm doing the same as you on my DVD player, but looking to find Elna RFS and maybe Nichicon LG, LF, LV (poly electrolytic type) that fit in the space available, but with about 1.5-2 times the capacitance.
worth replacing the pcm56p-k in an old cd player? badbrother Digital Source 3 8th September 2007 08:17 AM
CD player output caps - calculations reaction Digital Source 5 28th May 2005 02:37 PM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
Why does a cd player need a clean power supply? wazzup Digital Source 61 4th November 2003 09:41 PM
replacing diodes in my tubed-cd player jarthel Tubes / Valves 3 12th July 2003 03:03 PM
Page generated in 0.07149 seconds (71.37% PHP - 28.63% MySQL) with 11 queries
