Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th March 2010, 07:41 PM   #1
pftrvlr is offline pftrvlr  United States
Default Parallel TDA1541A DAC Noise
I got this parallel tda1541a DAC off ebay and have been playing with it for three weeks now. The DAC uses two parallel tda1541a chips. The I/V is a discrete current mirror circuit. Outputs from two tda1541a are wired directly to the I/V input
The DAC is working all fine with a single tda1541 in either of the socket. But when both tda1541 are plugged in, I can heard apparent noise/distortion - especially in the quieter music passages. The noise is not present when it is not playing music or it is between the gap of tracks. I switched different tda1541 chips in and out, some particular matches of tda1541 produce less noise, however it can not eliminate the noise completely.
This has led me to wonder if the I/V circuit is sensitive to matches of the tda1541a chips. Or two tda1541a may be in contention for bias current? Anybody has similar experience? Maybe each tda1541 need to be biased separately?
Old 28th March 2010, 09:57 PM   #2
My guess: each output has a nominal current. Parallel them on the same load (that's 1/2 of the single version one) and one of them will be forced to output more current while the other less - because of the inherent small diffecences.
You should build different I/V stages and parallel the outputs.
If you kept the same I/V load, then both of them will be out of the nominal current range.
Parallel TDA1541A non-o/s DAC Kits siu sin man tho Digital Source 89 14th February 2011 03:05 PM
FS: AYA DAC Rev 2.0b TDA1541A Non-Oversampling DAC kit or complete krishu Swap Meet 0 17th December 2009 09:33 AM
Parallel TDA1541A ... some clarifications required skje Digital Source 3 25th March 2008 01:11 PM
Only noise from TDA1541A based Sphinx Project 3 DAC Lucas Unger Digital Source 10 10th June 2006 12:53 PM
How many TDA1541A are needed in parallel to achieve double crown standard ? Blitz Digital Source 39 26th January 2004 01:26 PM
Page generated in 0.06665 seconds (66.77% PHP - 33.23% MySQL) with 10 queries
