Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th May 2006, 11:35 AM   #61
PHEONIX is offline PHEONIX  Australia
Default Reference system
Originally posted by Peter Daniel
After 2 days of listening, I'm pretty much tempted to remove the caps across the diodes in digital supplies as well.
ERO1830 0.01uF seemed to work best, but even those introduced certain veiling which seems too much of a trade off for smoothness. With the caps, the sound is loosing its "freshness", when they are removed, it's like the last curtain is lifted and gains in dimentionality are well perceived. The instruments suddenly have their own space, the sounds are _really_ 3-dimentional with layers of plans much better defined.
I started voicing the circuit without those caps in a first place, it may be different if someone does it with the caps across the diodes. It is possible that removing them then, has no advantage at all.
Hello Peter
Just Curious what do you use as your reference speaker, for your evaluations. What do you also do for music do you use commercial discs.
Arthur
Regar
Old 10th May 2006, 02:59 PM   #62
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
At the moment I'm using FAL drivers and Aurum Cantus ribbons with first order crossovers: Anybody tried FAL drivers?
As to the discs, it's whatever I can buy at local stores.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th May 2006, 03:07 AM   #63
I worked today with the caps in analog regulators section. The two smaller caps on the right (originally 220/25V) are input bypas caps. I initially tried BG N 10uF but the sound thickened and lacked air and resolution. I installed ERO 10nF and this worked fine. Any cap here is in parallel with main filter caps, and since I'm using there BG N 1000/50, nothing really worked well in parallel, always adding coloration; the 10nF was still better than no cap at all.
The two bigger caps on the left, originally 470/16, were quite problematic to choose. I tried here almost everything I had available (BG N, BG FK, Nichicon FG, Elna Cerafine etc) but nothing sounded right, it was always forward, colored with tension that was hard to accept.
In the end, I installed back the original caps that were here(Panasonic SU) and suddenly everything locked in place and I got the smoothenss and relaxation I remebered so well and valued in the sound of that DAC. The certain organic quality came back and I knew that those two caps need to stay
There are still two more caps I didn't test, but after pleasant experience I had with old caps, I'm not sure I would touch those.
I also tried to remove the snubber network on transformer's secondaries (for now, in analog section only) and definitely prefered the sound without snubbers (1.5uF in series with 100R). The snubber was adding coloration without any perceived sonic advantage.
www.audiosector.com
Old 14th May 2006, 07:32 AM   #64
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Re: DAC 7
Originally posted by Cobra2
The 1547 typically has one great limitation; the internal op-amp.
But luck is that you can tap the DAC-chip in front of the op-amp...
Arne K
http://digilander.libero.it/paeng/magnetics_frame.htm
Arne K
Ars longa, vita brevis
Old 14th May 2006, 09:33 AM   #65
ash_dac is offline ash_dac  United Kingdom
Default Re: Re: DAC 7...
Arne K
Thanks for the link.
Just to check on the tda1547 each channel of the switched capacitor outputs a standard, and an inverted signal.
So could I use it in single ended mode?
-This would increase distortion but adding an external I/V would be much more simple.
-The internal op amps seem to be referenced to ground which also makes external op amps easier to implement (rather than referenced to a 2.5V reference as in the saa7350).
-The summing amp could also be removed so only two op amps in the signal path.
Any thoughts ?
Old 14th May 2006, 01:29 PM   #66
[B] [/The 1547 typically has one great limitation; the internal op-amp.
But luck is that you can tap the DAC-chip in front of the op-amp...B]
I am not completely conviced yet that internal amp are such a big limitation, that's why I'm leaving that tweak as last, after everything else is taken care of.
Presently my setup is similar to Level First from your link, where I'm using S&B TX102 transformers. I have coupling cap installed as the ouptut from internal op-amps carries 40mV offset.
I'm certainly interested in Second Level of modification (bypassing internal op-amps and connecting transformer directly). What are the recommneded R and C values?
And thanks for an interesting link.
www.audiosector.com
Old 14th May 2006, 01:33 PM   #67
Default Re: Re: Re: DAC 7...
Yes, you can use it in single ended mode by connectig one side only of the balanced signal. I just did it two days ago, although the sound was somewhat less dynamic.
www.audiosector.com
Old 19th June 2009, 04:31 PM   #68
jpak is offline jpak  United States
jpak's Avatar
Peter any further mods been done to your BiDAT? Is it still your reference source?
Meitner/Museatex Bitstream DAC Help! ungie Digital Source 4 3rd September 2008 04:17 PM
Museatex IDAT-44 DAC. How good ? vadimgal Digital Source 1 18th August 2006 02:52 PM
FS: Museatex Bitstream DAC dimitri Swap Meet 0 15th January 2004 08:44 AM
Meitner AT-2 faxurda Analogue Source 7 18th November 2003 12:22 PM
Page generated in 0.12303 seconds (83.09% PHP - 16.91% MySQL) with 11 queries
