Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th April 2006, 08:00 PM   #21
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by rfbrw
Short of running it over with a steamroller, I can't see how you can make it sound that bad.
I'm not sure what you mean by bad, maybe your previous experiences. As you see, I'm pretty much open to anything and if I can try something, I always do.
I had (unmodified) Bidat in my system the whole weekend, and today I switched back to my (modified) NOS TDA1543. Read my lips: if you value the emotional content of musical reproduction, immediacy, involvement, finer detail, PRAT, the Bidat does not even come close. Well, I had to spend $1800 to learn about it.
Comparisons aside, I still feel that the unit has quite potential and when modified it may become much more listenable. By listenable, I mean a way of musical presentation where each musical note exists in each own space and expresses exact intentions of a performer. Unfortunately, I cannot perceive it using the Bidat presently. It produces nice background music, but it's not satisfying to the full extend of what's possible.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th April 2006, 08:21 PM   #22
Rob Thomas's Avatar
I'm curious if you're utilizing the Museatex CD-D transport with C-Lock to the BIDAT.
I found the BIDAT always sounded best patched balanced into a true balanced amp, and utilizing the BIDAT wired remote. This is the closest I got it to comparing with modern day magic. I agree that this unit likely has much hidden potential.
-Rob
Old 24th April 2006, 08:28 PM   #23
I'm using modified ML37 as transport (presently it sounds better than my other ML31.5).
The balanced Bidat output is connected to S&B TX102 (in balanced mode), and to Patek amp in bridged mode.
I was checking last night Audioasylum posts on bidat, apparently the DAC remote volume control is not that desirable.
I don't want to be misunderstood, I'm not saying that Bidat is no good, it's just that being spoiled by _well implemented_ NOS TDA1543 in proper setup, I'm not that easily satisfied these days
www.audiosector.com
Old 24th April 2006, 08:50 PM   #24
My impression of Bidat sound over the last two days is the certain rightness without all the usual whistles and bells. It is the sound that is rather correct, yet not "impressive" enough to grab your attention and keep you in your chair thinking how could you live without it for so long. You won't find here unfamiliar sounds you had never heard before on your favourite CDs and probably won't find yourself tapping toes.
It is still the sound that is not much spoiled by digital processing and it still gives a promise of a great potential to be unleashed.
When I switched to Bidat I thought it was less colored, yet after switching back to TDA1543, I don't feel the coloration is here either. But I feel like the curtain was lifted and all the music is finally unleashed as well.
www.audiosector.com
Old 24th April 2006, 09:34 PM   #25
Rob Thomas's Avatar
I find the BIDAT only excells driven by the CD-D. Meitner's C-Lock mechanism provides admirable jitter specs... (Other opinions on trnsports vary widely here.)
From the BIDAT manual, ( http://www.museatex.com/bidatman.htm ):
Jitter: Less than 10 PS. No periodic jitter. Crystal based PLL clock recovery system.
"Sounds which have been digitally recorded (i.e. quantized in time and magnitude into digital words) must be decoded at an equivalent sample rate and magnitude in order to accurately reproduce the original sounds. The stability of the sample rate clock directly affects the accuracy of conversion and it is easily shown by calculation that the required clock stability at 8Fs can be no worse than 50pS peak-to-peak in order to achieve 16-bit accuracy. This kind of deviation from perfect clock stability is called phase jitter or time jitter.
The accumulation of jitter through the playback chain is examined in a AES technical paper entitled "Time Distortions within Digital Audio due to Integrated Circuit Logic Induced Modulation (LIM) Products" in which the mechanism of jitter propagation called LIM is identified and a Museatex measurement tool for jitter analysis is introduced.
This research has led to the development of a series of proprietary Museatex circuits which prevent or reduce jitter in digital audio systems. An audio D-to-A converter must by necessity derive its timebase from the input audio data. The recovery of this clock is usually performed by one of a handful of standard IC's, all of which are sensitive to degradation of stability by every component of the preceding playback chain including the interconnecting digital cables. Yet the overall performance of the converter depends critically on the clocking of the conversion IC's with a clock having very low jitter.
C-Lock-R™ is a proprietary data receiver which uses a radically different clock recovery method. It has low sensitivity to jitter and LIM products carried in the received data stream. This provides the Bidat with low- jitter system clocks having high immunity to LIM and jitter caused by the sourcing equipment. Furthermore, this circuit ensures that any remaining jitter has a random or "white" frequency distribution allowing for clock distortion accuracy below the 20-bit level.
Museatex has made this receiver available under license to interested parties.
C-Lock-T™ is a proprietary reclocking circuit which ensures that jitter is removed from digital outputs. This circuitry has received critical praise as used in the Museatex Melior CD-Deck, a unit which outputs a fraction of the jitter produced by competing high performance drives costing many times more.
Other C-Lock™ jitter attenuators are used to ensure that the D-to-A conversion IC's in the Bidat are driven with sufficiently stable clocks."
[/QUOTE]
The BIDAT wired remote works by controlling the reference voltages at the D/A converter. It does not attenuate the digital signal as many do. None the less, I've found the BIDAT does seem to sound best with the gain stage fairly wide open with the right amp/speaker pairing, but is no slouch greatly attenuated internally, (VS adding pre/attenuators.)
-Rob
Old 24th April 2006, 10:31 PM   #26
Not being a fan of the DAC7 chipset, were I to ever own one of these, I would give serious consideration to trying out a different dac probably the AD1862 or the PCM63.
Old 25th April 2006, 12:20 PM   #27
ash_dac is offline ash_dac  United Kingdom
Thanks for the pics. Aside from SMPS PS (and some small caps) everything else looks the same. My software ver. is R1.5.
I will be heavily modifying that unit soon, to hopefuly bring its certain performance aspects closer to what I'm used to with NOS TDA1543 DAC
Looking at your pic's, the technical description, and the DSP filter/ DAC 7 chipset I can't see what there is to modify!
I'd try to see if there is a software update / new chip for the DSP filter. Tda1543 sound version ?
By heavily modifying I assume you mean patching in a td1543 dac on to the saa7274 receiver?
Old 25th April 2006, 12:42 PM   #28
No, I actually mean redesigning completely PS and output stage, as well tuning the DAC auxilary components.
www.audiosector.com
Old 26th April 2006, 05:24 AM   #29
Tonight I did the first step into modding and changed the rectifiers,as well removed all those ceramic bypasses (on bridges).
And I already begin to like the DAC: the sound gained immediacy and is more open.
I used RGP 15B I was using previously with good results in a transport.
www.audiosector.com
Old 26th April 2006, 05:26 AM   #30
Here's the closeup of replacement bridges.
www.audiosector.com
Meitner/Museatex Bitstream DAC Help! ungie Digital Source 4 3rd September 2008 04:17 PM
Museatex IDAT-44 DAC. How good ? vadimgal Digital Source 1 18th August 2006 02:52 PM
FS: Museatex Bitstream DAC dimitri Swap Meet 0 15th January 2004 08:44 AM
Meitner AT-2 faxurda Analogue Source 7 18th November 2003 12:22 PM
Page generated in 0.12547 seconds (82.64% PHP - 17.36% MySQL) with 11 queries
