Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
View Poll Results: DO you want a HDMI -SPDIF convertor
No 9 16.36%
yes < $200 37 67.27%
Yes > $200 9 16.36%
Voters: 55. You may not vote on this poll
Old 30th January 2012, 05:05 PM   #61
My ideal setup would be a box that can split HDMI to one SPDIF out per channel. There would be a single channel DAC mounted right next to or on the back of each speaker, along with an amplifier. Thay way the analog lines are kept as short as possible, and there is no need for fancy analog cables that go the distance between the processor/receiver and each speaker.
It might be possible to tap into the I2S lines of a HDMI device and add a module that converts each I2S channel into a mono SPDIF (so the signals can be sent the distance to each speaker). Each DAC on the receiving end would need to be configured to accept a mono SPDIF signal.
Old 16th March 2012, 06:06 AM   #62
pingfloid's Avatar
Hi.
The HDMI to video + SPDIF converters are now on Ebay for around $43.
Since Android devices still do not officially support the connection of a USB DAC, I am thinking about this alternative to extract digital audio (2 channels only) from a tablet with HDMI output.
Do you know if the quality of the Digital Audio is not affected? Just the same as a regular coax digital output?
Thank You
ps:
If you have a spare click, please vote to increase the priority to implement the feature of the USB_CLASS_AUDIO compliant device DAC feature on Android devices :-)
http://code.google.com/p/android/issues/detail?id=24614
You need to be registered on google mail, and click vote at the bottom of the page
Old 16th March 2012, 07:02 AM   #63
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Thanks for the heads up - done.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 16th March 2012, 12:29 PM   #64
SPDIF does not support uncompressed multichannel audio. The highest rate it supports IIRC is 192KHz 24 bit x 2 channels. HDMI can support the same over 8 channels, maybe more. So the output from this device will be similar to using the SPDIF or Optical output from your source player - compressed.
Old 16th March 2012, 12:51 PM   #65
Saturnus's Avatar
Much lower in fact. One has to remember that SPDIF is an ancient very outdated standard.
If you follow the SPDIF standard it's 20 bit 48KHz max for PCM. The 4 extra bits for are an optional extension that most recievers will understand but not all. You risk LSB cut. Many SPDIF recievers can also recieve 96KHz but that is entirely not standard and you risk sample drops.
The SPDIF signal has a max standard transfer rate of 3.1Mbps. Even the lowly old USB 1.1 standard has 4 times that transfer rate capacity.
Old 16th March 2012, 01:30 PM   #66
macboy is offline macboy  Canada
S/PDIF is standardized as IEC60958-3, and it supports up to 192 kHz at up to 24 bits per sample. Rates higher than 192 kHz are also supported for encapsulated data transfer, but not for raw PCM audio samples. Some older equipment was limited to around 6 Mbps, which placed a limit to 96 kHz (always 64 bits transmitted per audio sample x 96 kHz ~= 6 Mbps). It is always possible that older equipment will truncate lower bits.
combine SPDIF and DVI to HDMI output calvin14 Digital Line Level 3 1st July 2009 01:39 PM
DC Convertor? zeonrider Power Supplies 2 8th November 2007 02:26 PM
Simple convertor ? zeonrider Parts 4 7th November 2007 09:52 PM
A/D 24bit/96khz convertor help sunny Digital Source 1 16th October 2006 12:35 PM
XLR Convertor Dark Shadow Parts 4 26th October 2003 03:19 AM
Page generated in 0.10602 seconds (78.05% PHP - 21.95% MySQL) with 11 queries
