Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th February 2013, 12:04 PM   #81
Mooly's Avatar
I would doubt it very much. Its probably part of the laser power control circuitry.
A simulation free zone. Design it, build it, test it.
Old 16th February 2013, 12:19 PM   #82
Salar is offline Salar  Germany
It drives the laser diode as far as I understand. 2SP1013 is connected to transistor RM2401 which has JW600 connected to its base. (JW600 was the resistor with wrong value . 330ohm soldered in, but 10ohm in datasheet)
Old 17th February 2013, 02:32 PM   #83
dacen is offline dacen  Norway
Increasing the power on reset timing was not the solution to this problem. Hmm, have another thing I want to try and that is to give the power supply to the laser a separate voltage regulator with a deacent HF decoupling. Will advise in a while.
Old 18th February 2013, 08:36 AM   #84
Great, thanks! Eager to hear results.
Old 19th February 2013, 02:00 PM   #85
Another "test": Had the Player switched on for 45 Minutes without playing. About 15 degrees centigrade ambient temperature.
After those 45 Minutes I started playing a CD. The CDP-X5000 skips when playing it. So the parts prone to cold must be parts that heat up when the X5000 is playing.
Old 22nd February 2013, 06:38 AM   #86
The arcs I am talking of, r the tracks on the cd. Near the centre of the CD, the head has to respond faster. The spin motor also has to have tight tolerance so the already difficult tracking does not become more difficult.
Gajanan Phadte
Old 22nd February 2013, 10:25 AM   #87
The fault is completely independent from that. It happens in the outer tracks as well as in the inner tracks. It is related to temperature, not progression of the CD.
Also relative speed to the laser head is the same from inner to outer tracks.
Old 22nd February 2013, 03:27 PM   #88
my player works fine if i only warm it up without playing ...
Old 22nd February 2013, 03:30 PM   #89
...reading errors occur only for the first or second track of the cd without warm up...if i play a track that is not near the center of the cd, even without warm up i get NO reading errors...
Old 22nd February 2013, 03:32 PM   #90
aahhhh this is really confusing!!!!!
SONY CDP-X5000... Open house... (No, not for sale... :P) Maniac Digital Source 0 3rd September 2007 04:35 AM
Troubleshooting Sony STR-DE975 dj_vulture Solid State 0 29th May 2007 05:17 AM
Helios X5000 Media Server mike_mcf Digital Source 0 27th January 2007 02:50 AM
Newbie Troubleshooting Sony CD Changer zozeppelin Digital Source 0 15th June 2004 01:03 AM
looking for Sony X5000 Service Manual. tone Digital Source 0 21st February 2003 03:10 PM
Copyright ©1999-2013 diyAudio
