Sony X5000 troubleshooting - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th February 2013, 08:20 AM   #41
Salar is offline Salar  Germany
There is no arc. The laser optics sit on a pole and are driven horizontally/vertically by coils for fine trackment and focus.
Old 9th February 2013, 02:18 PM   #42
i've just tried to let the player warm up without playing any disc for 15min,then tried to play one...well,no reading errors,definetely it is not a problem of the transport mechanism.
Old 9th February 2013, 03:00 PM   #43
Dear il capo, good to hear, same with my CDP-X5000.
I still think, it is a manufacturing error from and we (who live in cold areas) have to find a workaround for it.
Maybe Dacen knows more, did you read his reply? (#25 in this thread)
Old 9th February 2013, 07:41 PM   #44
dacen is offline dacen  Norway
Well here is what I have found today. There is a mismatch between the schematic and the servo board regarding the base of transistor Q601. This is a transistor that has to be brought well into a conducting state as it is the supply to the laser diode. Follow the signal from the collector of Q601 to pin 9 on connector CN210 at the bottom on the page. The other end is pin 4 on the laser side(LDVCC). For some reason the resistor JW600 going from the base to ground had the value 330 Ohm. The schematic says 10 Ohm. This is a small surface mounted resistor right underneath the board where the RST IC sits. I removed this resistor and replaced with an ordinary one with leads on the ends and the value 10 ohm as printed in the schematic. Well the startup problem is gone so far. Have to see as time goes by, but this could potentially also cause the skipping problem as well. We have to see ?
Old 9th February 2013, 08:32 PM   #45
PlasticIsGood's Avatar
At last! An unambiguous test
Old 9th February 2013, 08:40 PM   #46
Originally Posted by dacen View Post
... Well the startup problem is gone so far. Have to see as time goes by, but this could potentially also cause the skipping problem as well. We have to see ?
Excellent. Is this the common problem? Mistake or last-minute ill-conceived solution to some other problem? Hopefully the former.
Old 9th February 2013, 09:05 PM   #47
This is what I ment to say:
Have to see as time goes by, but this could potentially also cure the skipping problem as well. We have to see ?
Old 10th February 2013, 08:41 AM   #48
Great news dacen! Thanks a lot!. Because we have winter now, canīt you put the CDP-X5000 to a colder place, or not heat the room where it is, for one night. 10-15 degrees celsius ambient temperature is enough. I am very economical with heating my appartment, most of the time ambient temperature is about 15 degrees, which causes the X5000 to skip the first half hour.
In the summer,, it can max out to 40 degress: No skipping...
Old 10th February 2013, 09:21 AM   #49
Just looked into the service manual: In the electrical parts list, page 46, Sony calls the resistors JW600 (2%) and JW601(5%) "Jumper Resistors" and defines them as "Metal Glaze" resistors. I thought, jumper resistors are generally 0 ohm...?
Old 10th February 2013, 02:18 PM   #50
Yes Salar, this puzzeled me as well. I measured the resistance and they are just ordinary resistors. They could be "Metal Glaze" or whatever. May be somebody in here can enlighten us here. JW, I would normally translate to "Jumper Wire" but they are normally not specified with a tolerance to them.
SONY CDP-X5000... Open house... (No, not for sale... :P) Maniac Digital Source 0 3rd September 2007 05:35 AM
Troubleshooting Sony STR-DE975 dj_vulture Solid State 0 29th May 2007 06:17 AM
Helios X5000 Media Server mike_mcf Digital Source 0 27th January 2007 03:50 AM
Newbie Troubleshooting Sony CD Changer zozeppelin Digital Source 0 15th June 2004 02:03 AM
looking for Sony X5000 Service Manual. tone Digital Source 0 21st February 2003 04:10 PM
Copyright Đ1999-2017 diyAudio
