Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th March 2010, 04:43 PM   #1
tiefbassuebertr's Avatar
Default Information wanted about Accuphase DP-70 DAC: 4 pices Intersil's 4-bit ICL 8019ACPD
4 pices Intersil's 4-bit ICL 8019 forms a 16-bit discrete and very fine sounded digital to analog converter by Accuphase's DP70.
For this integrated circuit I need datasheets and replacement parts. Only suppliers I find some on the web, but no data sheets or other helpful informations.
Here URLs from Italian forums:
Integrato ICL 8019 cercasi...
COSTRUIRE HIFI • Leggi argomento - Urge trovare un ICL 8019 !!!
I don't understand, why there are no pdf datasheets about alldatasheets, digchip and datasheetarchive. Perhaps because ICL 8019ACPD" was custom made version?
Please note, the attached 20 bit DAC block diagram is from DP70V instead of DP70, but also discrete version and basicly very similare
Old 19th March 2010, 06:45 PM   #2
I had the same problem with a PCM1745E (DAC made by BurrBrown). I even asked TI for a datasheet but they politely deined to provide one, saying that was a special order .
Old 19th March 2010, 09:20 PM   #3
Which CD/DVD/BD Accuphase model uses this type? I think, this type is close to that one of PCM1742 or PCM1748 with slightly different internal low pass filter characteristic
First commonly informations regarded 4-bit D/A converter like ICL8018-8019-8020 I have found here:
http://www.analog.com/static/importe...als/MT-015.pdf
Old 20th March 2010, 04:35 AM   #4
amc184 is offline amc184  New Zealand
amc184's Avatar
I had a look at making a similar thing to this (a discrete DAC), but somewhat simpler. I think the part you are looking at is probably a shift register that de-serialises the digital signal.
There is such thing as a 4019 4-bit shift register, four of those stacked would make a 16-bit shift register, which fits together with what I would expect to see. A lot of these sort of ICs are no longer available, mainly due to the current prevalence of CPLDs and FPGAs.
If you post some more details, such as the surrounding circuit and some photos of the IC in question, I may be able to suggest a replacement.
Old 20th March 2010, 09:22 AM   #5
here I find several informations:
Patent EP0063878
and the same with high resolution text but without showed figures:
(WO/1982/003490) METHOD AND APPARATUS FOR PROCESSING AND PACKAGING DIGITAL DATA
Old 20th March 2010, 11:45 AM   #6
aparatusonitus's Avatar
ICL8019A datasheet and Application Note, Data Sheet, Circuit, PDF, Pinout | Datasheet Archive
Non é mai abbastanza...
Old 20th March 2010, 12:02 PM   #7
Bernhard's Avatar
It is a 4 bit current switch.
I have 4 x ICL 8018 C in completely gold plated ceramic package, not soldered.
No idea if there is a difference to "A" version.
Email me if you need some. 10 EUR per piece + shipping.
Accuphase DP-90 laser head dazzdax Digital Source 9 24th January 2010 01:55 PM
wanted information! vellman vaa-70 tube amp onlytubes Tubes / Valves 3 23rd December 2008 04:43 PM
Accuphase DP-55V Darry Solid State 0 29th December 2006 11:16 AM
use digital attenuation to improve 16-bit CD playback on 24 bit DAC capslock Digital Source 7 8th April 2002 11:18 PM
Page generated in 0.08740 seconds (83.50% PHP - 16.50% MySQL) with 11 queries
