| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am messing with a cdrom and trying to get it to be a cd player. A simple task, but being a pain.
If I plug in the Analog out connectors at the rear to output to rca sockets my headphone jack switches off as would be expected. However no sound is coming out the analog outputs. I dont want to output to my amp through the jackplug as I want to rehouse the unit in an enclosure to match my amp and would like to have the rca outs. Anyone else had this problem before and how can I get round it. |
#2 |
I would head to the local library and page through a stack of Elektor Electronics. I'm pretty sure they've done it sometime in the past decade and a half...
I know they built their own CD player, but it used a premade transport.~Tom |
#3 |
Hi littlerick,
Take a look at this thread, it might be of interest to you Another CDROM Controller Kit |
#4 |
I'm not to worried about the display n stuff, its just a prototype to mess with... Working is all I need at the moment.
I'll worry about pretty when its going
#6 |
It has two buttons on front... One is for the eject and the other is a play/next track button.
It works and plays fine, my only problem is trying to use the analog output on the back. It cuts the headphones but no sound comes through amplifier. |
#8 |
I have no idea... I plug it into a pc power supply... put a disk in and it will play through the headphone socket at the front. When I plug my cable into the rear analog out, it cuts the headphone socket off, but no sound comes out to the amplifier.
I figured if its got analog output attached it should work. |
#9 |
I’m not 100% sure what the CD-ROM “Analogue Out” is used for
, but I’m pretty damm sure that it isn’t analogue audio. The digital signal will need to be processed through a DAC to get usable audio
#10 | |
These days CDROM drives usually don't have analog outputs, or headphone jacks, but they all used to. Can't tell why littlerick's analog out isn't working, though. |
| Best opamp for my cdplayer. | wandelblu | Digital Source | 32 | 7th December 2009 03:20 AM |
| uf4002 diode in my CDplayer | abiedoodles | Digital Source | 2 | 15th September 2007 06:44 AM |
| Noisy cdplayer ? | mirland | Digital Source | 0 | 21st October 2005 08:19 AM |
| cdplayer transformer faulty | tone | Digital Source | 1 | 9th August 2002 10:32 PM |
| Page generated in 0.09854 seconds (77.51% PHP - 22.49% MySQL) with 10 queries |
