Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th March 2010, 08:37 AM   #1
Send a message via AIM to yammy1688 Send a message via MSN to yammy1688
Default Replaced clock, now music plays 1.7x slower
Hey all,
I recently replaced the cheap crystal on my sound card with one of the ebay clocks and now my music plays sllloooowwwww....
Now at least according to the labels on both clocks, both are 24,576, but for some reason, when any sound is played through the new clock, it goes quite a bit slower, 1.7x to be exact.
Could there be anything to cause this aside from a defective/mislabeled crystal, or perhaps some multiplier of sorts built into the sound card somewhere?
I've removed two caps and resistor associated with the crystal, and it's too late to put the old one back as I may have damaged it during removal from too much heat (just get choppy static with old clock).
The good news is that even though it's slow, i can already tell that it's quite a big upgrade sound-wise. cleans everything up so to speak and brings out all these little details.
Any help would be appreciated!
-ken
Old 19th March 2010, 06:56 AM   #2
I forgot to add that this occurs whether the power supply is plugged in or not, so I suppose it may be a power supply issue.
Does anyone know if an improperly powered clock would exhibit this type of behavior?
Old 19th March 2010, 07:08 AM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Could you have mis-wired the new clock to the soundcard?
How have you connected it ? Photos would help.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 19th March 2010, 07:29 PM   #4
OK so it turns out it simply wasn't receiving any power. I mixed up the secondary cables from the transformers (it's the kind where both secondaries are the same colors). Once I re-wired it, checked for vac on the board itself and voila!
So let this be known: an unpowered clock can work without power, just slowly. I simply assumed that it wouldn't work at all without power, and thus expected it had something to do with the clock itself.
Makes very appreciable difference BTW. Great use of $45
Hope someone finds this useful!
-Ken
Old 19th March 2010, 11:05 PM   #5
poynton's Avatar
probably the board was actualy free running rather than the clock working without power
Old 19th March 2010, 11:07 PM   #6
What does free running mean?
Old 20th March 2010, 12:16 AM   #7
wwenze is offline wwenze  Singapore
The crystal couldn't have been running without power while being connected to the circuit at the same time, because the only two pins of the crystal where it connects to the circuit are also where you apply power.
Old 20th March 2010, 01:15 AM   #8
So it was being powered by the sound card?
Old 20th March 2010, 03:25 AM   #9
Maybe, but without the extra power to the clock and just power from the two pins on the card and affected by other components on the clock PCB the resonant frequency of the circuit was undesired.
I don't think the card would be playing music without a clock, at least mine stops totally when I select external clock and resumes when switched back to internal.
rockford fosgate punch 200ix transformer plays music? spooney Car Audio 2 15th October 2007 12:04 AM
Veravox 7x one1speed Full Range 40 28th April 2006 09:59 PM
Music plays after amp is turned off. Killjoy99 Solid State 29 10th January 2005 06:32 AM
It plays music!!!! Mikael Abdellah Tubes / Valves 5 1st September 2003 06:41 PM
Page generated in 0.10812 seconds (79.51% PHP - 20.49% MySQL) with 10 queries
