Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th March 2010, 01:34 PM   #1
Salar is offline Salar  Germany
Default 2nd. Generation Laser Units HLPL030020 and OHP-32
I have two service manuals, Nakamichi OMS-5 and Toshiba XR-Z70.
Laser for the Nak is "HLPL030020", for the Tosh it is "OHP-32"
But comparing the drawings of the manuals, both lasers look to me like twins.
Can it be the same model?
BTW, in the Manual of the Nak, a name of the laser pickup is not even stated, you´ll have to open it to check...
All the best,
Salar
Old 12th March 2010, 06:53 PM   #2
tiefbassuebertr's Avatar
Toshiba "OHP-32" ?
I haven't heard about this type until this day.
mean you that one from post #43 about
KSS-122A and KSS-123A - Are they Interchabgeable? ??
The "HLPL030020" (NEC) is listed also by compact disc player KYOCERA DA-910
there are some infos about NEC Laser by Nakamichi
Ersatzlaser für Nakamichi OMS-5, Elektronik (Stereo&Surround) - HIFI-FORUM
What mean "comparing the drawings of the manuals" ??
The exploded view for laser unit or the schematic diagram?
Old 12th March 2010, 07:57 PM   #3
Sorry, it is OPH-32.
The Kxocera DA-910 is almost the same as the Nakamichi OMS-5 and 7, ecxept the display and it´s drivers, which seems to be LED and not VFL.
In the service manuals, I mean the exploded views and disassembly/mechanical setup drawings.
Same location screws and pins, housing looks the same, etc.
But the rest of mechanics is different, I had no time yet, to check the schematic diagrams for similarities in APC or servos...
Old 13th March 2010, 02:11 AM   #4
The Toshiba laser is extremely similar in appearance to the NEC, but I can confirm from experience that they are NOT interchangeable.
Old 13th March 2010, 07:59 AM   #5
Thanks a lot!
Do you rememer, which players you serviced?
Old 13th March 2010, 09:53 AM   #6
The main reason for not interchangeable laser heads, that have same mechanical outline, is the use of different laser diodes (and sometimes different PDIC resp. OPIC).
The laser diode itself could be e. g. a P-SUB or N-SUB type in the same TO outline. Thus are also different APC circuits in use. This is also true by the integrated monitor diode on the same chip.
If you have failured compact disc player with one of this here mentioned laser head, it isn't expect, that the laser head is the reason therefore (in opposite to the KSS series from SONY).
Old 14th March 2010, 01:41 AM   #7
The players I specifically remember with that Toshiba head are the Yamaha CD-1(still one of the best looking players ever) and the Denon DCD1800(I think), whereas the players with the NEC are, of course, the Nakamichi OMS-5/7 and Kyocera 910/810(and 710?). Kyocera reportedly made the rest of that transport for Nak, although Nak did their own boards for it, as well as a discrete output module that you could disassemble, whereas Kyocera strangely tar-potted their output modules, making them unserviceable.
Disc Table Height with KSS-Laser Units Salar Digital Source 7 25th February 2007 12:58 PM
Identifying optical pickups/ laser units kora Digital Source 7 24th June 2005 12:11 PM
pwm generation sundeep2802 Class D 1 18th March 2005 06:39 PM
14 Units NOS Philips CDM9/44 Laser Mechanism tone Swap Meet 2 18th October 2004 05:00 AM
Page generated in 0.11735 seconds (72.15% PHP - 27.85% MySQL) with 10 queries
