| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi.
I have done the searches (including the net) and cannot find anyone with a service manual for a CD73. Does anyone have a service manual. Thank's. |
#2 |
Vintage Audio Laser - Schémas techniques / Schematics-
If there are problems, can send on e-mail. |
#3 |
Many thank's for the link, you are a saint.
I tried all over the place to get info, but all I got was a few bits/extracts, mainly in German or similar.Cheers. I managed to get most of the info off the site, and have sorted most of the problems. One thing I can't do though, is trace why the output is sooo quiet, and a little distorted. If anyone has had a similar problem, or maybe just has an idea of where I should look, then I would welcome the advice. Would the TDA1540d chips be at fault? It would be a shame to relegate this machine to the "spares or repair" bin. Cheers. |
#4 |
On health! You have the remarkable device! TDA1540D Is fine and best chip!!!
All its problems is a bad contact and old condensers with which it is necessary to replace. And if you use tube SE the amplifier, make remove filter SAA7030(NOS) and reclocked with a good food, I/U on the resistor and the transformer instead of all analogue (opamp) I/V buffered. Good luck! Excuse, for my bad English.
#5 |
Thank's again.
I'll re-seat the chips and check the circuit for faulty components like you suggest. I don't think I have the skills to re-clock the unit, and to be honest, all I want to do is actually get it to work. It was in bits when I got it, and I paid over £100.00 GBP for it, which has not gone down well with my fiancee, so just to get it to play would be enough to justify the price. Anyway, I'll have a go and let you know. Cheers for now. |
#6 |
Hi again.
I've just had a look at the decoder board and it has completely different chips to the ones listed in the circiut diagram. As my knowledge of electronics is limited to descreet devices, I have no idea what to make of it all. I have attached a picture of the board, and here is a list of the chips that are on the diagram; SAA7030 TDA1540 (X2) SAA7010 SAA7020 MAB8410 (I think this one is correct) SAA7000 Apart from the MAB chip, the others appear to be completely different. ![]() Any idea's? |
#7 | |
It is normal, Philips 300\303 and Marantz 73 have two variants of execution, with the decoder from Philips with a set 7000/7010/7020 and executed on a separate payment with chips Sony, (the second variant more musical). Probably you have a scheme 2 variants? I can send you on e-mail service a manual of 1 variant. To begin with it is necessary to check up pressure on a food payment. Good luck! |
#8 |
Hi.
I would very much appreciate your variant 1 manual. My email is; mschwilson@aol.com Thank's also for the power diagram, It's much easier to understand than off my manual. I checked most of the components on this board already, but I'll do it again just to make sure. As a matter of interest, none of the components are marked on the board, would the manual include a layout of the circuits? not to worry if not. Thank's again for your help. Cheers for now. |
#9 |
Magneto the Gravity Man
You just have an old version of the board with the "MK1" chips (pre-production numbers)
Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#10 |
As far as the quiet output is concerned, is it one channel or both??
It could be that the muting relays are not working on "PLAY". Andy .
| marantz cd73 service manual | pengxy | Swap Meet | 1 | 2nd October 2009 09:22 PM |
| Service manual modern Marantz | Stuey | Solid State | 11 | 25th September 2008 08:30 PM |
| Marantz CD7300 Service Manual | gbyleveldt | Digital Source | 0 | 16th July 2008 11:30 AM |
| Looking for Marantz CD65II service manual | electropt | Digital Source | 9 | 24th March 2007 09:56 AM |
| Marantz CD63 Service Manual | johnmarkp | Digital Source | 8 | 19th May 2006 09:33 PM |
| Page generated in 0.10928 seconds (79.21% PHP - 20.79% MySQL) with 11 queries |
