Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th March 2010, 01:14 PM   #1
EIRA is offline EIRA  Netherlands
EIRA's Avatar
Default Marantz CD-94 spindle motor
My dearly beloved CD-94 has a spindle problem. Laser moves up and down after closing the tray, but the disk is not spinning. When I put the machine on its side, press on/off button, it makes 1 rotation, and then stops.
Should I now replace the complete drive?
Your advice is very much appreciated
Eira
Old 5th March 2010, 02:37 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Clean the laser first.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 5th March 2010, 04:47 PM   #3
guido is offline guido  Netherlands
guido's Avatar
Find the service manual and use the service mode to do a first troubleshoot.
Usually it's powering on the unit with 3 keys pressed. Trick is to know which keys
If you see only "0" are something like this in the display, you're in. Then next key will jump to the next mode. One mode is focus, one is the arm (can then be moved with << and >>) and one is spinning the disk (maybe in a different order, can't remember). Last one is playing music.
All philips based players have such a mode i think.
GuidoB
Old 6th March 2010, 11:12 AM   #4
oshifis is offline oshifis  Hungary
On older units the belts get stiff/loose and the tray in end switch does not engage. Check the belts first and replace them if necessary.
Old 6th March 2010, 03:23 PM   #5
EIRA's Avatar
Thanks Guido, I read the service manual, and indeed, the server mode is accessed by holding PLAY, STOP and Search >> simultanuously while powering on. The manual says there should be 1 zero, but my CD 94 gives a double zero. Strangely enough, the NEXT key does not switch to level 1, 2, or 3. machine looks completely dead in its further responses.
oshifis, I replaced all belt 6 months ago and that part works really well.
Any further suggestions?
Thanks,
Old 6th March 2010, 04:26 PM   #6
guido's Avatar
Check the service manual for the key which progresses to the next level.
Maybe it's not next. But if it is, it's not succeeding to get to 1.
Think focus is first, but iirc it depends on the transport. If it is focus, try without a cd. You should see the lens go up and down as it is attempting to focus.
You can also look if the laser works (it needs to work for focussing). Look at it FROM AN ANGLE in without much light in the room. Not straight in (niet recht van boven). You should see a red glow around the lens.
What transport is in there? cdm0, 1 or 1mk2?
GuidoB
Old 6th March 2010, 04:31 PM   #7
EIRA's Avatar
Thanks, Guido. I will check later this evening. there is CDM-1 inside
Old 7th March 2010, 10:44 AM   #8
EIRA's Avatar
Hi Guido,
After entering into serviceloop 0 (no disc inserted), pressing NEXT key moves the laser up en down 16 times. This is according to the service manual. No visible light emitted from the laser, though.
Pressing NEXT again should start the motor to spin the disk, but this does not work.
Pressing SEARCH > and < moves the laser from center to edge and back, according to the service manual.
With disk inserted in loop 0, nothing happens at all, laser should move up and down until focussed, but it does the same 16 up/downs as without an inserted disk.
My conclusion is that the laser is not working. I do not know if this also causes the motor not to spin.
DO you know if the laser can be replaced?
Old 7th March 2010, 03:32 PM   #9
guido's Avatar
Think it is possible to replace just the laser with cdm1, but i don't know too much on these units. Think you need to go through an allignment procedure afterwards. And you can't just get lasers heads easily (allthough there was a thread on this here i think).
I would try to find a working cd104 or something like that to swap the whole assembly. Check the kringloopwinkels or MP.
But first have a look at the electronics surrounding the laser. Maybe there something failed, or maybe even a powersupply problem. Wouldn't hurt to get a spare cdm1 machine anyway. I have a B&O CD-X here and a cd104 for spares, my only cdm1 stuff.
GuidoB
Old 13th March 2012, 05:11 PM   #10
Hi EIRA,
Were you able to fix your CD 94 issue?
Mine was very similar, got the double zeros when I tried the service loop. I opened the cover and realised the CD would try to rotate but was not able to do so. I adjusted the clamper height by following the instructions in this post (see attachment). Player is singing well now. Worth a try if you still haven't been able to fix yours .
Marantz cd94: belts for loading tray
Marantz CD-94 EIRA Parts 1 24th June 2010 11:12 AM
Anyone compared Marantz CD-94 and CD-94MkII? oshifis Digital Source 3 6th February 2010 12:56 PM
Marantz CD-94 poorly again culpano Digital Source 2 3rd August 2009 08:14 PM
Marantz CD 94 sch Zoran Digital Source 21 6th June 2006 09:34 PM
Looking for Marantz CD-94 schematic Peter Daniel Digital Source 7 13th August 2002 02:26 AM
Page generated in 0.10436 seconds (80.47% PHP - 19.53% MySQL) with 10 queries
