Musical Fidelity x10d schematics here - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th June 2003, 12:35 AM   #1
Cool Musical Fidelity x10d schematics here
Use Systran at Altavista
Old 3rd February 2004, 07:56 AM   #2
CJAVIER is offline CJAVIER  Spain
Hello,
Sorry but I dont understand russian language. Anyway I saw this schematics has an error. The GND is tie to Vss. This is shortcut.
Id like if possible an english version about it.
Thanks.
Old 3rd February 2004, 02:00 PM   #3
frenzic is offline frenzic  Netherlands
Via http://babelfish.altavista.com/
Tube Buffer Mf-x10d
Very flattering opinions about this toy printed solid and authoritative audio- periodicals. However, which is located inside the small "keg" of well-known producer, who was being let out from 1995 through 1998 and order 170 usd in reteyle confronting I will try to explain in this article.
First of all the diagram:
Diagram of buffer (one channel)
Lamps 6922 (it 6DJ8, it THE 23P- EVAS). Transfer capacitances - polypropylene (Taiwan, for 3 rubles), resistors - 1% metal-film, S2-. As can be seen from diagram - two cascades in the class "A", envelopped by feedback.
Power source
The filament power supply of lamps is achieved by an odnopoluperiodym rectifier (diod+emkost'+tokoogranichivayushcheye resistance). Very module of nourishment - primitive quadrupler of the stress by no means _ of audifil'skogo _ quality, which ensures the supply voltage for the diagram of the order of '0-"0V from the transformer with the stress into y2V.
My realization - the same, only here nourishment is entirely different - stabilized both for the anodes and for the incandescence (moreover with the selection of stress 6.3 and 12.6 v, what makes it possible to use different lamps - 6922, 1U7, ECC82).
The common form of the construction:
Printed-circuit board:
For which I would recommend this device - cheap D -ple1ery, sonic systems on the base of computers. the "warm" sounding of lamps, saturated by even harmonics will allow you less to tire with hearing of sonic programs from these devices. This not Hi-End is certain, but if we gather independently, then 30-40 American rubles it is possible to obtain a little pleasure)).
Old 3rd February 2004, 08:23 PM   #4
Bat is offline Bat  Europe
I'm not sure about this schematic. Can anyone tell me what the grid bias on the 2nd tube is supposed to be? The way it's drawn, it looks like 0V to me.
Old 18th February 2008, 06:48 AM   #5
jpfastre's Avatar
Is there anyone who knows the answer for this question?
Old 18th February 2008, 07:09 AM   #6
QSerraTico_Tico's Avatar
Unhappy Re: Musical Fidelity x10d schematics here
[QUOTE]Originally posted by JDowland
[B]Use Systran at Altavista
404 error (not found)
Old 18th February 2008, 03:00 PM   #7
ckng is offline ckng  Singapore
I don't see any schematics....
CK
Old 18th February 2008, 08:48 PM   #8
Archwn is offline Archwn  United Kingdom
if you are refering to x10-d v1, i would say it is a normal anode follower + cathode follower sort of thing. the v2 is something different which use tube as a front differential amp with aid of TR ccs sort of thing. and a TR current gain stage.
Some say it use the same schematic on x-can v2 and v3 as well. I don't really know, but seriously to me, v2 is totally outperformed by simple headphone amp using simple opamp config like c-moy kind of thing - by miles. Though I haven't tried v3 but as schematic is almost the same I would think it shouldn't be any better.
Wonder why these gears won so many prizes as it didn't sound nice at all. and many say v3 sounds a lot better than v2 I really can't see why.
Any thoughts?
Old 18th February 2008, 09:21 PM   #9
jpfastre's Avatar
Is this tube constructed to handle the grid current with zero or positive grid bias?
Or is there an error in the schematic diagram?
JP
Old 29th March 2013, 05:02 AM   #10
Gost22 is offline Gost22  Bolivia
Banned
Question tube buffer x10-D with 6n23p-EV
Hi, all!
Do not open a new topic, I want to ask a question about tube buffer x10-D .
Is anyone tried this tube buffer with Russian tube 6n23p-EV (russian military), if he tried to play, is giving a good sound?
Here's schematics:
thank you!
musical fidelity x10d schematic arvin Tubes / Valves 79 11th February 2017 05:38 AM
Using a Musical Fidelity X10D as a Valve Buffer. Shoog Chip Amps 1 24th March 2013 03:37 PM
Musical fidelity A2 schematics jmmartins Solid State 16 8th February 2010 11:25 PM
Musical Fidelity A3.2cr Schematics Alexandru Solid State 1 26th September 2008 12:40 AM
Musical Fidelity Schematics? Sampsa Solid State 1 22nd June 2006 01:59 PM
Copyright 1999-2017 diyAudio
