| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am replacing a laser pickup in my Marantz SA-11s1 SACD player.
(It uses the Hitachi HOP-1200R laser) Would someone recommend a lubricant I should use for the rails that the laser pickup slides on? |
#2 |
I am not sure the rails are designed to be lubricated. If you did, it should be a dry film type of some sort. Krytox based maybe.
#3 |
Manufacturers have their own potions and stuff
Is it metal on metal or is there any metal on plastic involved. For CD pickups I use a special "plastics" grease that's suitable for use on metal/plastic too. When you find something that works you tend to stick with it. This stuff, ELECTROLUBE|SPG35SL|SPECIAL PLASTICS GREASE 35ML | CPC
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
I use Dry Glide dry film lubricating treatment with Teflon to lubricate slides.
For gears I use TAMIYA grease - excellent: Tamiya America Item #87025 | Ceramic Grease Boky |
#5 |
Official Court Jester
round metal rails - any type of thin oil
slides of any type , also all sort of gears - vaseline there is no need for over-engineering there
my Papa is smarter than your Nelson ! tnx to |
#6 |
From my experience, the oils draw dust and are bad for rails, in particular if left uncleaned for long time…
Also, some types of gear grease will harden over time, causing mechanical and electrical stress - resulting in intermittent problems.... but whatever works for you... stick to it. Boky |
#7 |
A plastic safe grease like silicone grease or Molylube is suitable for cams and the roller guide tracks. The techs I know swear by Molylube, it has proven itself in VCRs. Haven't tried lithium grease. Never WD40!
#8 | |
But in general - the sliding behavior between metal and plastic is highly dependent on the type of plastic, thus also fom the kind of lubricant. I have heard of certain oils, which decompose the plastic. Regarded the sliding behavior between metal/metal I think the same than ZEN-MOD. Here the overview of all products from Mooly's suggestion brand by post #3 http://www.electrolube.com/049/docs/catalog.pdf (German) http://www.hkw.co.uk/docs/catalog.pdf (english) Here an URL regarded replacing of Hitachi's HOP-1200S: Replacing laser pick-up Last edited by tiefbassuebertr; 9th March 2010 at 05:47 PM. |
#9 |
Don't use any petroleum based oil or grease unless it's only on metal to metal contact even Vaseline is petroleum based, if there is any plastics involved they will decay in time either softening or become brittle.
This is the "cheapest" safest grease I've found for plastic or metal, it's caster bean based, no petroleum products used. PBR disc brake rubber seal grease. PBR Rubber Grease - 17.5 gm tube, prices Cheers George |
| Onkyo laser pickup | jpiroto | Digital Source | 12 | 5th April 2009 02:33 AM |
| Please look that Laser Pickup... | Zeljko | Digital Source | 11 | 11th March 2008 07:17 PM |
| Can anyone help me identify this laser pickup? | mr_push_pull | Parts | 3 | 14th December 2006 11:35 PM |
| Laser pickup needed | georgehifi | Digital Source | 4 | 24th May 2005 12:02 AM |
| Page generated in 0.12308 seconds (79.91% PHP - 20.09% MySQL) with 10 queries |
