| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have been reducing the power supply noise to a Tent XO module feeding a PCM1704 DAC.
With a TL431/BC156 series pass ps as posted widely, the measured noise level was quite high, at around 60 uV wideband. The sound improved over a resonant crystal arrangement, but not that dramatic. Reducing noise gradually by using OSCONs at input, across the TL431 and at the output, I managed to get noise down to about 15 uV and here the sound improved significantly, with clearer highs and better bass, and a much more relaxed presentation. Connecting a TL1763 LDO, however, I managed to get noise down to 8-10 uV, with reduced hf components but some 50 Hz evident in the trace. The sound has now become even better, with clear and smooth presentation. There was no need to use inductors at all. Getting to this stage wasn't easy, and many insitu measurements were made relative to changes to the ps. However, it has proved worthwhile in that the sound is now much better. May be I should try a battery next? Throw away your 7805 and LT1086s, and try something better. The LT1763 has 20 uV specified noise, but a 150 uf OSCON at the output did the business. |
#2 |
Hi Fmak,
So, do you have a schematic of you final design? Curious to see it. Randy |
#3 |
Me too! :-)
#4 |
[QUOTE]Originally posted by randytsuch
[B]Hi Fmak, So, do you have a schematic of you final design? Curious to see it. ------------------------------------------- Just the LT1763 SMT 8 (not available in anything else) with 220uf feeding input and 150 uf 6.3V OSCON SG at the output. The chip sits on a DIL adaptor and a 6x3 cm ground plane, with fly lead connection to the pins. The whole thing was quite laborious to assemble. The larger LTs have higher noise but are easier to mount. |
#5 |
How do you connect "sense" and "byp" pins in the LT1763 to the "out" pin?
#6 |
What type of XO do you have?
After reading your post I've been thinking about stacking some 9V batteries as a PSU for my XO3. |
#7 | |
I am happy to see that the hunt for low noise is paying off.... 8-10uV equals 8 to 10 nV/Sqrrt Hz, when 1 MHz BW is still used (Fred ?). Not bad for a commercially available LDO ! Using batteries, or a seperate transformer finally reduces the last trace of noise from a player, not to mention the last bits of potential ground loop problems succes to you all Guido |
#8 |
The ground loop / 50(60) Hz stuff can be the hardest to get rid of, but with care it's not difficult.
Try cascaded reg's, connected as tracking pre-regualtors and always take the outputs from the o/p and ref terminals of the reg. The latter bit is critical - if you take the o/p of most 3-terminal adjustables from anywhere other than the adj terminal sense point (i.e. where the R / C connect) you'll get signficant measurable and audible noise increase, which is a killer to a clock supply. For digital (NOT analogue) supplies an AD8065 in a Jung reg gives VERY low noise that will be hard to maintain by other means. This solution sounds better than a quieter AD797-based supply in my CDP, I suspect this is the better HF dynamic noise characteristics where the ear may be more sensitive to phase noise. The noise on the PSU can be viewed as a modulation of the clock, the spectra is pretty important in my experience. Andy. |
#9 |
#10 |
| Problem with Kwak Clock power supply | Bricolo | Digital Source | 97 | 18th January 2007 06:16 AM |
| Building power supply for master clock questions | KevinLee | Digital Source | 15 | 31st March 2004 12:38 PM |
| LM317 as power supply for kwak-clock | jarthel | Digital Source | 8 | 8th May 2002 05:15 PM |
| Page generated in 0.11272 seconds (82.83% PHP - 17.17% MySQL) with 11 queries |
