| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Building cd line stage.
125-125 v, 12.6 heaters running a single 12AU7 What gauge hook up wire for: A) Main B+ wire? B) Ground buss wire? C) Ground ties? D) Heater wires? E) Input/Output signal wire? |
#2 |
The hook up wire has to be solid core, or ribbon if you can obtain ribbon.
Pure silver, annealed is very good… and even better if you can gold plate that silver. Pure silver ribbons, annealed and then gold plated are magic. Natural cotton sleaving is brilliant. Bear cables (air dielectric) is the best. If you can’t get this stuff, use solid core copper – like in CAT5 cables. For larger currents use multiple runs of the same cable with slight twist. The worst: multi-litz cables.... Boky |
#3 |
Thanks for replying. Very helpful.
I was also looking for gauges of signal, heater and B+. |
| Newbie Asks: What Gauge Hook Up Wire? | JimOfOakCreek | Parts | 3 | 8th July 2007 04:02 AM |
| which gauge wire for PSU???? | cbutterworth | Tubes / Valves | 6 | 13th December 2006 12:52 PM |
| does the gauge of wire matter | bangin out | Car Audio | 11 | 4th April 2006 03:53 AM |
| Wire gauge calculator? | xyrium | Multi-Way | 7 | 12th October 2005 10:36 AM |
| fet wire gauge | MikeZ | Pass Labs | 2 | 21st April 2004 12:43 PM |
| Page generated in 0.08589 seconds (64.46% PHP - 35.54% MySQL) with 10 queries |
