Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th February 2010, 06:07 PM   #1
Gizmo2 is offline Gizmo2  Canada
Default 12AU7 CD Linestage CHoke Value.
Building a 12AU7 cathode follower line buffer after a stock 2 volt cd player.
Want to run a simple C-L-C using (2) Solen 47uF PPE caps.
Told to buy a Hammond 5H choke.
My power supply is 125v-125v, 12.6v heaters.
There are so many different values of 5H chokes
http://www.tubesandmore.com/scripts/...RC&PAGE=SUBCAT
Want to end up with 95-100 vdc B+
What choke should I buy?
Old 20th February 2010, 10:19 PM   #2
RIP
50 ma is plenty. You're in the wrong forum.
Old 22nd February 2010, 04:45 AM   #3
kevinkr is online now kevinkr  United States
kevinkr's Avatar
I'd repost this query in the tubes forum or ask a mod to move this thread there.
You might want to try Duncan Amplifiers PSUD2 power supply design software - with a little work to understand the software it will tell you pretty accurately what the value of the input capacitor and the dcr of the choke needs to be to hit your target voltage.
Ask questions there and other forum members will pitch in with their advice which may also include some negative comments about the 12AU7's linearity. (It's not the best, but in CF operation probably won't contribute significant distortion if the load impedance is reasonable.) In case you are interested (and it is not necessarily the case that you should be.. ) the 5687 is a commonly available alternative, has better linearity and much higher transconductance making it a very good cathode follower.
www.kta-hifi.net
Elekit - TU-884CD 12AU7 Vacuum Tube CD Player vkung Elekit 7 7th February 2011 06:10 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Cycline3 on the 12AU7 Cycline3 Tubes / Valves 24 28th October 2007 04:20 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 08:30 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
Page generated in 0.07065 seconds (74.45% PHP - 25.55% MySQL) with 10 queries
