diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   SONY BDP-BX2 doesn't power on (http://www.diyaudio.com/forums/digital-source/161701-sony-bdp-bx2-doesnt-power.html)
yzriver 20th February 2010 04:06 PM
2 Attachment(s)
MY Sony BDP-BX2 doesn't power on. When I plug in, there is no any response on panel, and I click the power switch, still nothing on.
I take off the cover, measure the voltage of each the pin out of the power board. The voltage are all fine.
Does it mean the problem happen in the main board? any DIY solution?
thanks a lot.
Extreme_Boky 24th February 2010 09:19 AM
Well... get the service manual and start fault finding... there might be some fuseable resistors that went open... it is highly unlikely that you measured all rails okay while the unit was switched off at the front. Maybe re-check…
Boky
Copyright 1999-2017 diyAudio
