Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Deriving I2S from Sony CDP
Old 6th June 2003, 07:06 AM   #1
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Deriving I2S from Sony CDP Send a message via AIM to Peter Daniel
Default Deriving I2S from Sony CDP
Here's the schematic of the DSP and digital filter section in my Sony CDP620 player. I'm trying to get I2S from DSP and connect it directly to TDA1543. I'm not sure if I used proper connection, as I got very week signal in left channel and noise in the right one. I made the following connections from filter pins (CX23034) to TDA1543:
pin 8 (BCLK) -----> pin 1
pin 7 (Data) -----> pin 3
pin 6 (WCLK) -----> pin 2 of TDA1543
plus I connected ground from Sony board to the TDA1543 chip.
Will it work?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 6th June 2003, 07:26 AM   #2
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb I2S from Sony chip
Hi Peter,
Very probably the signals coming from the DSP are not Philips I2S format but Sony/Burr-Brown format.
You can convert the Sony format to I2S by the schematic published by Kal Rubinson in the Audio Amateur 1, 1997.
Backissues available at www.audioxpress.com
Old 6th June 2003, 07:30 AM   #3
Would it be possible then, to connect the signals coming from DSP to AD1865 DAC maybe?
www.audiosector.com
Old 6th June 2003, 07:51 AM   #4
Banned
Lightbulb AD1865
Hi Peter,
yes I did that in my old Sony as my first NON-OS experiment. Sound is too soft though as you are not using the two MSB bits . With the AD1865 actually you need some kind of zero stuffing scheme. Porobably also the reason Audionote is using the CS8414 in there CD-2 CDP. The 16 bit AD1851 gives normal output in the Sony but sounds worse than the AD1865.
Old 6th June 2003, 09:29 AM   #5
Bricolo is offline Bricolo  France
Bricolo's Avatar
if it's in sony/bb format, why not trying non os with a BB DAC?
Old 6th June 2003, 10:32 AM   #6
Banned
Lightbulb BB-DAC
Hi Bricolo, I did with the PCM56.
Bass was very good, highs were bad.
Old 6th June 2003, 11:32 AM   #7
Bricolo's Avatar
Default Re: BB-DAC
due to what? the pcm56 don't like non os?
Old 6th June 2003, 11:43 AM   #8
Banned
Cool Re: Re: BB-DAC
Hi Bricolo,
I think it is due to the DAC. The PCM56 is a first generation DAC. The AD1851, also 16 bit, was a lot better overall.
Old 6th June 2003, 11:46 AM   #9
Bricolo's Avatar
Default Re: Re: Re: BB-DAC
Hi Bricolo,
from what i've undsetood on the "how does a delta sigma dac work?" topic, R2R seems better (no HF garbage) for non os
but on the manufacturer's sites, i can't see which one is r2r or d/s
which dacs are R2R?
Old 6th June 2003, 12:08 PM   #10
Banned
Default Re: Re: Re: Re: BB-DAC
from what i've understood on the "how does a delta sigma dac work?" topic, R2R seems better (no HF garbage) for non os
which dacs are R2R?
Well Bricolo, if you read the datasheets you will find that most manufacturers mention the kind of DAC
AD1851, AD1865, PCM56 are R2R
All Crystal/ Cirrus Logic are Delta-Sigma.
AD1853, AD1854, AD1855, AD1857, AD1858, AD1859 are all Delta-Sigma. Most Delta-Sigma DACs have built in (on chip) digital filter and are thus unsuitable for a NON-OS application.
I which catogory the TDA1543 & TDA1541 DAC belong I don't know
Deriving I2S from Sony CDPHide this!Advertise here!
deriving T/S parameters from common specs hitsware Full Range 8 5th January 2009 03:12 AM
Deriving Secondary Voltages dre7 Tubes / Valves 0 16th October 2007 08:41 PM
Deriving WS from a 24.576MHz clock? Lovan Digital Source 6 15th November 2006 04:44 PM
Deriving I2S from Philips LHH CD players ... deskmate88 Digital Source 0 7th June 2003 08:45 AM
Copyright ©1999-2017 diyAudio
