DIR1703 vs. CS8416 SPDIF receivers - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th June 2003, 01:04 PM   #1
Question DIR1703 vs. CS8416 SPDIF receivers
Hello,
I plan to start some new DAC projects and the great question is the S/PDIF receiver: DIR 1703 or CS8416
benefits: DIR1703 : lower 75pS jitter!; 384xFs recovery ability /to be used with some Digital Filters/
CS8416 : more inputs /8 or 4/ ; easily to buy in BG ; Crystal is tradittional manifacturer of Receivers
Can anyone comment the sound of the one vs the other?? Are 75pS jitter for DIR1703 just "on-paper" better than those of the CS8416?
DACs to try with generally are AD1860, AD1862N-J, AD1955, AD1853.
also I tend to try AD1895 as jitter reduction circuit
Old 4th June 2003, 09:24 PM   #2
I don't know about the CS8416, but I can say that the DIR1703 is sensitive to high jitter sources and does not tolerate them well. I had a DAC that used one and it proved unusable with a sony CD Walkman optical output. They was random popping added by the receiver, or at least the designer said that's where it was coming from.
Stu
Old 4th June 2003, 11:38 PM   #3
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
If you are using an AD1896 ASRC you might as well not worry about the jitter in the receiver circuit. The datasheet on the DIR1703 is so illiterate, the reader is left wondering whether the part actually does anything or not. I would avoid it and go for the CS8415.
You can't buy the CS8416 anywhere, as far as I know.
Old 5th June 2003, 08:38 AM   #4
Smile CS8416
Thank you both!
JWB, the AD1895/6 was an option for the higher-end device, but there will be also a design without it. It was told me by a distributor around, that CS8416 and CS8415A can be supplied to me in small quantities for $4.5, so I think this is possible. But now I wonder wheter it is possible to supply parts in Bulgaria that can not be supplied in West Europe
By now I have a good experience with the AD1892 Receiver/SRC, but this was the only aviable receiver here before so I couldn't experiment w. others.
DIR1703 is not so frequently mentioned anywhere, but Crystal's receivers have good reputation. I guess I'll go for a design with CS8416 or CS8415A as a replacement.
Thanks again
SPDIF on cdrom to SPDIF on Digi Crossover davidallancole Digital Source 0 11th January 2007 04:26 AM
cdrom spdif quality / sound card spdif metebalci Digital Source 0 2nd September 2006 08:16 PM
Dir1703 dmfraser Digital Source 13 13th December 2004 07:27 PM
DIR1703 spdif question jwagnerhki Digital Source 9 6th May 2004 09:14 AM
CS8406, CS8416 => 192kHz SPDIF Dave Digital Source 5 11th January 2003 03:20 PM
Copyright 1999-2017 diyAudio
