Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Best way to clean CD mechanism?
Old 3rd June 2003, 10:15 PM   #1
Nicwix is offline Nicwix  Australia
Default Best way to clean CD mechanism?
Hi there
I have an old Marantz player - platter seems a bit sticky - what is the best way to clean this (main bearing and swing arm) and with what?
Nic
ps have seen threads on ATF as a lube.
Old 5th June 2003, 08:00 AM   #2
mekanoplastik is offline mekanoplastik
i use pressurized air and toothpicks ....
take apart the transport, then try to push all the old lube away from the gears by blowing it away usign the pressurized air ( i use air cans, always keep then vertical ) then remove the blops of old sticky lube with the toothpicks, repeat the process until all is very clean and then use the right type of lube (for metal or plastic gears, dont lubricate metal to plastik) try to avoid cotton or fabric as cleaning materials as they will leave little fibers...repeat the process until you are sure all the old lube is replaced by the new one....also, use some oil for the bearing/bushings, and be careful of not aplying too much lube ..
good luck
Best way to clean CD mechanism?Hide this!Advertise here!
Best CD drive mechanism Hyldal Digital Source 197 23rd January 2017 09:00 PM
A cueing mechanism to buy/DIY theskintman Analogue Source 1 30th June 2008 01:47 PM
Cueing mechanism BluesMagoos Analogue Source 0 1st May 2007 08:17 PM
Philips 12.1T/06 Mechanism stj Digital Source 0 28th April 2004 02:19 AM
Copyright ©1999-2017 diyAudio
