Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver
Old 29th January 2010, 06:38 AM   #101
cbdb is offline cbdb  Canada
Its all about the error correction. Theres always a percentage of pit misreads off any optical disc, but the data can come off perfect every time (or not at all). When was the last time you pulled a word document off a CD and a few words changed? If you convert your music to wave files and store them on CD, they will come back bit perfect (even spinning 48x or vibrating the computer). The error correction on audio CDs isnt as good as data CDs but as I understand it the only time bits are "lost" is when there are C2 errors. Does anyone know how often these occur in a average CD player?
Old 29th January 2010, 06:42 AM   #102
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I avoid Word as much as possible. It is a terrible piece of software.
But i get what you mean. You do have to get it off the audio CD to start with thou.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th January 2010, 06:48 AM   #103
Sure and there is software that tells you how many errors you got when you ripped the CD. I seem to recall there werent that many C2 errors, the hard part was burning audio CDs without lots of C2s
Old 29th January 2010, 07:03 AM   #104
Mooly's Avatar
Chris deserves a big thank you for taking the time and trouble to help explain the actual processes at work here... and to keep reminding folk that we are dealing with what is an analogue signal off the disc. Discs don't have 1' and 0's, pits and lands are not directly representing 1's and 0's. The change from 1 to 0 and vice versa occurs whenever there is a transistion from pit to land and vice versa. This is also intimately related to the wavelength of the laser "light"... the difference in "height" between a "pit" and a "land" is the difference between "light is reflected back" or "no light is reflected back". That microscopic difference in "distance" the light travels allows for "cancellation" or not of the reflected signal.
CDR's... any recordable disc is fundamentally "different" here as there are no pit's and lands, just reflective material, or non reflective (where the state has been altered by burning). The "edge" definition of these transistions is far less well defined than a pressed disc.
As an aside to this, and I know Chris will have found this many times when looking at RF patterns, that if you just lightly "hold" the leads to a pickup the RF deteriorates so badly with noise/jitter... you name it, yet the player goes on regardless.
I think I read in there "you hear what you want to hear" or something along those lines.
I think that sums up most "tweaky" arguments here, not just this thread but cables, burn in of IC's etc etc.
Good on you Chris
Old 29th January 2010, 09:34 AM   #105
On Hiatus
SY's Avatar
Its like saying demagnetizing my camera lens has improved my pictures. Would you believe that, if so I have products to sell you.
Excellent analogies, may I steal them sometime?
As Scott and I posted a few pages back, hardly ever (I used my old cheap 1988-vintage Magnavox for that test).
And Chris, a terrific job of explanation. My deepest thanks to you.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 29th January 2010, 09:58 AM   #106
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I remember Peter van Willenswaard doing this measurement for a variety of CD snake oil treatments and finding... zero difference.
I also remember reading that Peter van Willenswaard thinks the green pen on the edges of a CD improves the sound of a CD.
I have never heard a difference. But then again I never did any serious comparison/did not have a good enough hifi system/good enough ears.
Old 29th January 2010, 10:01 AM   #107
Magura is offline Magura  Denmark
Magura's Avatar
Sorry to bring you bad news Bas, but you're just plain deaf, like the rest of us whom can't hear the difference
Which would lead to the conclusion, that SY is stone deaf!
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 29th January 2010, 10:40 AM   #108
godfrey is offline godfrey  South Africa
Originally Posted by malcontent View Post
AFAIK PC clocks are dithered to reduce RF emission, so that can't be good. Not sure if the card attempts to re-clock or not. But, that is jitter, not data.
The good news is there's often a BIOS setting that allows you to switch that off.
IIRC the magic word is "spread spectrum" (for my Gigabyte motherboard anyway). Turn that off to get a constant clock speed.
I found out about that in context of the effect it might have on system stability when overclocking.
It didn't occur to me till now that it could also jitter the audio. Duh!
Thanks for the heads-up.
Old 29th January 2010, 10:49 AM   #109
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
2500 access numbers within 3 days (and also some very interesting URL's and attachements), and such intensive discussion - I never expected this in this matter.
Old 29th January 2010, 10:51 AM   #110
On Hiatus
SY's Avatar
Religion and faith are always controversial.
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound ImproverHide this!Advertise here!
Ultra Compact Sound System jonkun227 Everything Else 4 28th July 2008 04:44 PM
Improving Sound Quality of a car amp coki Car Audio 0 25th June 2007 04:50 PM
Further improving the sound of my fostex BLH wboyd Full Range 8 1st February 2006 05:23 PM
Improving sound card digital section - beginner questions halcyon Digital Source 3 21st November 2005 12:39 PM
