All Diyaudio Threads about not available Optical Pickup's from Sony's KSS-Series - Page 8 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st April 2013, 08:29 PM   #71
Default Sony CDP-101
Hi guys,
I have as mentioned simillar but older player Sony CDP-101 but I have oposite problem: when I turn ON the player, the spindle motor spins like devil and spins and spins without stopping.
had some of you this problem fixed before?
thank you
Old 22nd April 2013, 12:41 AM   #72
expert in tautology
bear's Avatar
suggest starting new specific thread with ur question...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 3rd May 2013, 09:42 PM   #73
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
tubeboob:
i just saw your post.
thanks for posting this.
did you ever get your machine "fixed"?
i have a 779 that, probably once a month, shows this issue.
i plan to open it and take some measurements.
sony has bit me repeatedly in the past with cold solder joints, especially in TVs and in particular, the tuner modules. after the last one, i switched to mitsubishi, only to get bit by the smd leaky caps problem.
mlloyd1
Originally Posted by tubeboob View Post
Here's the quote:
"The Vintage Knob‬
Sony CDP-X779/707ES & other models using the same transport‬
‪ ‬by ‪ilimzn‬ Mon May 16, 2011 12:01 am
Also titled: are you sure it's the laser going bad?
Users of these fine machines and also related models using the same mechanism based on the KSS272A laser block, that have problems with their machines reading some discs, may find this of use:
Two problems that often crop up that look like the laser may be going bad, but are NOT laser related at all, so be sure to check:
The above problem pertains to all CDPs with the same mechanism, that would be CDP-X303, 339, 505, 559, 707, 779 and corresponding Japanese model designators.
The following problem is specific to the CDP-C779/707 (and Japanese market equivalents):
I sure would like to know, as my X707ES still works most of the time, and the symptoms listed here fit mine to a "T".
Just hard to find a "competent" tech to look at my unit.
I also have a spare (X339ES) in mint condition for when I have to.
Comments welcome and appreciated, as I, and all of us here, need help.
Cheers
Old 10th June 2013, 10:04 AM   #74
SonyES is offline SonyES  United Kingdom
This is a handy site to show what Sony units have which lasers:
TVK: Sony resource: laser pickups
Old 10th June 2013, 08:57 PM   #75
tiefbassuebertr's Avatar
good overview - thank you.
the mentioned item numbers of laser diodes under post #17 about
TOSHIBA DLBA2Z002B laser
are suited not only for the KSS-151A. I think, this diode is suited for the most of the KSS-series also for KSS-272A, KSS-273A and KSS-274A.
The actually question is now, which companies are there to carry out the exchange and the follow adjust of the APC circuit.
Old 20th July 2013, 09:16 PM   #76
Originally Posted by mlloyd1 View Post
tubeboob:
mlloyd1
I haven't had it looked at as this particular CD player is sitting in its box in storage. I haven't found a competent tech that I trust to handle the repair. If you know any one in the NYC area, please let me know.
Last time I played it, it played just fine, and the issue is intermittent.
How did yours turn out?
Who did your repair?
Cheers
Old 20th July 2013, 09:33 PM   #77
mlloyd1's Avatar
tubeboob:
i did my own repairs. however, as i get older i find i enjoy doing repair work less and less though. i guess it's my 55 years old eyes and fingers, while electronics keeps getting smaller.
i have seen no problems with the machine since the repairs, but it was a very intermittent issue, so it's probably too early to declare victory ...
ilimzn's original message contains the useful info:
"The solution is simple: change R961 from 4.7k to 820 ohms.
There are a few optional steps that can be taken to further improve things, including long term reliability:
Changing C963 from 2200uF/10V to say 4700uF/6.3V additionally improves Vee stiffness and stability. Often just doing that without the R961 fix reduces the skipping problem, clearly showing Vee is the culprit.
The 5V output is invariably a bit high, around 5.2 - 5.3V. It can be trimmed closer to 5.1V as stated in the manual by soldering a 27k resistor in parallel to R956, on the bottom side of the board. This is important because the laser head is supplied with this voltage, so overvolting is not at all desirable here. The 6V voltage (incorrectly labeled as 7V in the manual!) is not that critical and can be left alone."
i made all the recommended changes.
mlloyd1
Old 21st July 2013, 09:47 PM   #78
Thanks for the update.
Cheers . . .
Now to search out a proficient tech . . . . . .
Old 7th August 2013, 11:09 AM   #79
Default KSS210A
Recently got hold of a sony CD player which uses KSS210a laser and found it was jumping around unable to read all the tracks. I had the same problem on an Arcam 7 and replaced the laser there - no problems.
So i got a new kss210a from HK and fitted it to the new sony, and the motor does not spin up, put the old one back, motor spins OK. Checked wiring to see if I'd busted something, all seems fine.
got out big magnifying glass to see if there was any difference between the 2 - they seem identical.
I read somewhere about removing an ESD strap on the KSS210A. I can't see any difference between the old and new one, so my question is - is there an ESD strap and where is it
CHeers Tim S
Old 25th March 2014, 08:35 AM   #80
check out post #32 about
Laser Diode Successor of SLD-104U for SONY ESPRIT KSS Series
Laser Diode Successor of SLD-104U for SONY ESPRIT KSS Series tiefbassuebertr Digital Source 32 6th June 2015 09:22 AM
Sony optical pick-up KSS 273 A cdun Digital Source 11 1st December 2014 04:46 PM
Databook about SONY's KSS optical pick up series tiefbassuebertr Digital Source 9 12th December 2011 06:26 PM
diyAudio can no longer accept political threads. EC8010 The Lounge 0 28th September 2005 06:16 PM
Copyright 1999-2017 diyAudio
