| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
About 5 weeks ago I bought a non working audio alchemy Digital Drive System 3 CD player. The problem was it would not read any disk that was inserted. The seller told me that it is a common thing for the ribbon inside to go. So he gave me a few links to order the part. The part number he gave me was Sony 153747211 FILM JUMPER WITH TERMINAL. First is that what I need? Also what will I have to do to replace the ribbon? If there is solder involved I will be fine but just want to be ready. Thanks in advanced.
#2 |
The AA DDS-III is basically just a cheap Sony CDP-290/291 inside. The ribbon cables don't go bad unless someone gets in there & damages them. If it's failing to read discs, but otherwise gives good display, etc., it's almost 100% certain to be a bad Sony KSS-240A laser, which is neither expensive nor hard to find, and fairly easy to replace, given any mechanical talent at all.
#3 |
Thank you for that info do you have a link to the part I need?
#4 |
Well, dalbani.com is showing stock of KSS240A at $15 each, and there are various sellers on ebay in the same or slightly higher ballpark.
#5 |
Thanks I will have to take a look at them.
| High fidelity Audio & My Ribbion Speaker Project | FrankCashio | Planars & Exotics | 43 | 2nd April 2010 07:16 AM |
| audio alchemy powersupply | PAICE69 | Power Supplies | 24 | 21st March 2007 01:45 PM |
| Audio Alchemy | jcsveth | Digital Source | 1 | 27th December 2006 07:49 PM |
| audio alchemy ps 3 | PAICE69 | Swap Meet | 0 | 24th March 2006 08:33 PM |
| audio alchemy help | HIPCHECK | Digital Source | 2 | 1st June 2005 07:11 PM |
| Page generated in 0.07337 seconds (73.26% PHP - 26.74% MySQL) with 10 queries |
