| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Qiujiao SAA7350 and the PMD100 chip I2S connection between the
For the DAC, the digital receiver demodulation is a serious impact on the sound link, DIR-chip differences, as well as to restore the clock accuracy, would give rise to differences in the sound, while the severely affected part of the sound input aside part of the receiver demodulator, the signal is direct access to turntable, and with CD turntable to use the same clock source, DAC strictly synchronous with the clock dial, compared with traditional coaxial, optical fiber interface, a very big advantage of the non-verbal. Similarly, for the CD turntable, such as the output signal directly from the DAC chip, the same can avoid a lot of serious impact on the sound stages. The I2S provides us with a convenient signal connections. Hope all our friends to the in Zhijiao are extremely grateful! |
#2 |
#3 |
#4 |
SAA7350 datasheet
http://datasheet.eeworld.com.cn/pdf/6353_PHILIPS_SAA7350.pdf |
#5 |
Hi sn2777,
You don't need any digital filter, SAA7350 can be connected directly to I2S Philips digital format...as I have done in my Philips CD930 cd player.
Non é mai abbastanza... |
#6 |
Hello aparatusonitus:
If convenient, could you describe in detail, because I am a rookie, a little do not know. My CD machine is Philips 931, DAC is a MUSICAL FIDELITY X-DAC. |
#7 |
The PMD100PDF document on page 17, there are Connecting the PMD-100 to the Phillips SAA7345 Demodulator I2s Mode, can be used as reference.
#9 |
Hello panomaniac:
不好意思,我不懂英文。 简单地说吧,有一台飞利浦931CD和一台MUSICAL FIDELITY X-DAC,想让它俩之间用I2S格式的一条信号线连接,传递信号。 Sorry, I do not know English. Well simply, there is a Philips 931CD and a MUSICAL FIDELITY X-DAC, wanted Talia I2S format used between a signal line connected to signal transmission.</SPAN> </SPAN> |
#10 |
| i2s connection question | stephan-schulz | Digital Line Level | 2 | 25th March 2009 04:23 PM |
| How to Control Dither on PMD100 Chip? | fastcat95 | Digital Source | 1 | 1st September 2007 11:36 PM |
| I2s connection for cdpro2 and pcm1704 | joekjtam | Digital Source | 2 | 20th May 2006 12:13 PM |
| Audio Alchemy I2S connection? | quantran | Digital Source | 4 | 3rd October 2004 12:46 AM |
| Whic DAC chip to use with a PMD100 filter?? | Brussel Sprout | Digital Source | 19 | 5th February 2002 09:25 PM |
| Page generated in 0.11040 seconds (77.07% PHP - 22.93% MySQL) with 11 queries |
