| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all ,
I am working on a output LPF of a PCM 2702. Using AD712 as buffer. The power supply is as shown : ![]() But there is hum noise from the buffer stage ,i can hear clearly although it is doing the LPF work and a buffered sound coming with the noise. The connection is shown below... ![]() Help me with this one , could it be due to 2 different grounds? i saw KECES dac schematic the are using a floating line from PCM2702. Or , is it due to the cheap transformer i am using (for testing,later will add a toroidal). |
#2 |
R.I.P.
More likely the opamp/buffer is oscillating at some high frequency, which always sounds like hum. Can you post a schematic for it?
Regards, Allen |
#3 |
#4 |
yesterday i have checked Power supply with dropper of 4.7k in series from +15v ,
tried to drive a fiio e3 ,there is some problem,it cant drive! normally supply shows voltage checked with LED. is 9-0-9v, 500 miliamp secondary supply transformer too less?
Lets find the truth..inside! |
| HIFIDIY.net PCM1798 USB DAC with Tube Buffer | bongoman | Digital Source | 22 | 30th December 2009 01:12 PM |
| Modified USB DAC board, DDDAC with triode buffer | wa2ise | Tubes / Valves | 6 | 21st September 2008 11:57 PM |
| USB powered NOS USB DAC with built-in headphone amp | dsavitsk | Digital Source | 15 | 10th August 2006 06:11 AM |
| Generalized LPF for DAC | tiroth | Digital Source | 0 | 3rd January 2002 01:16 PM |
| Page generated in 0.08035 seconds (71.98% PHP - 28.02% MySQL) with 10 queries |
