diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Removing the Muting Transistors of Sony CDP-690 (http://www.diyaudio.com/forums/digital-source/157464-removing-muting-transistors-sony-cdp-690-a.html)
Xperience 28th December 2009 01:53 PM
Hi everybody.I need help of removing the mut.trans. where are they?how they look?and after removing what to do?Just switch on the CD player or need to connect the cutted wire ?
Mooly 29th December 2009 07:39 AM
1 Attachment(s)
They will be like this on the output of the final opamp and probably surface mounted too... this is from a Mini Disc recorder... but the set up will be similar.
Sometimes (occasionally) there are two transistors with a resistor inbetween to give a higher level of muting...
Just remove them... personally I don't believe it will make an audible difference... although many disagree :) You might "think" it does but "has" it. Probably much better to fit higher quality opamps (depending on whats fitted)
Xperience 30th December 2009 05:45 PM
Thank you!You are right I removed them but there was no difference.This is my trying player so I sacrificed it :)
Mooly 30th December 2009 05:58 PM
Try different opamps... :)
Xperience 30th December 2009 10:29 PM
what is opamp?
Andrea: 30th December 2009 11:00 PM
Originally Posted by Xperience (http://www.diyaudio.com/forums/digital-source/157464-removing-muting-transistors-sony-cdp-690-a.html#post2026754)
I wouldn't do that... you risk ruining your player. The disadvantage may be significant...the advantage may not be.
Ouch, you already did it :)
Copyright 1999-2017 diyAudio
