Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Oppo Blu-Ray BDP-83 - has anybody fitted new clocks?
Old 18th December 2009, 09:17 AM   #1
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Default Oppo Blu-Ray BDP-83 - has anybody fitted new clocks?
Just curious. The Oppo BDP-83 has now been out for about six months and the online mod businesses are already doing their thing(s). The 27MHz clock is the first item that is obvious to upgrade. Has any of you DIY'ers done this for themselves yet and what has been your experience in A) ease of fitting new clock and possible complications, and B) what did you observe as far as performance.
Over to you guys.
Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 19th December 2009, 04:13 AM   #2
Just to add to above. Have anybody installed a Burson clock into the Oppo Blu-Ray? I believe they, Burson, recommend that two resistors forming a dividing network is required after the oscillator (3.3V) stepping down to 1.8V or lower (I have a Philips BDP service manual that says core voltage is 1.1V for MT8520 which I gather is basically the same chip used by Oppo).
Does anybody know what those resistor values are or have come up with other values and used successfully as well? This of course applies to clocks other than Burson's.
Joe R.
Old 19th December 2009, 06:43 AM   #3
arthur is offline arthur
Over to you guys.
Joe R.
carefully remove the 27m crystal , C194, C197 and R84.
the new clock signal i/p is the solder pad of the crystal that is closer to the mt8521 chip
Old 19th December 2009, 08:05 AM   #4
Thanks for the reply. But have you then run the Blu-ray sampler disk via HDMI out? You will see that the picture is continuously chopping, like flick... flick... flick... etc.
Right now I am running two BDP-83 players here in the following way. The output of the oscillator sees a voltage divider network made up of 100R and 50R. Note that attenuates then clock signal by 3:1 - I don't remove R84, it's still there.
Note that this means I am running 1.1V logic and that the MT chip is likewise, nowhere near 3.3V. The players work just fine.
This is why I started this thread. I believe that Burson Audio's clock is installed the same way via a voltage divider after the clock. I don't have proof but if I am right then what value resistors are they using and are the also attenuating 3:1 as I am?
Hope there is somebody who can enlighten on this topic.
But thanks form your input. Maybe you should try what I have done. How is your HDMI output with full 1080p?
Cheers.
Joe R.
Old 19th December 2009, 01:24 PM   #5
i use a 5v tcxo, then 2 logic gates(5 v ), nothing abnormal found.
Old 19th December 2009, 01:41 PM   #6
That certainly surprises me, you are feeding 5V to the TCXO or 3.3V?
Is there any domumentation that you have seen, especially on MT8520/MT8521 (Oppo uses OP8521G I believe) and what made you decide to use the Xtal pad closest to the chip as the XT_IN. I saw somebody posting a pic that shows he was using the pad furthest away. Are we just guessing or is there any actual docs that makes it certain?
Cheers.
Joe R.
Old 19th December 2009, 02:13 PM   #7
1) 5v work ok(2 stages 74vhc 04)
2)i use the solder pad of the crystal that is near the heatsink
the other solder pad i try does not function at all
3) i have modified 5 bdp83 already
Old 19th December 2009, 03:02 PM   #8
Thanks Athur, much appreciated.
Joe R.
Old 19th December 2009, 03:16 PM   #9
Oh, BTW, did you find that you absolutely had to remove R84? I would have thought it still would be a godd idea to leave it in? Did it not work properly unless you removed R84?
Cheers.
Joe R.
Old 19th December 2009, 03:38 PM   #10
sorry i have not tried
Oppo Blu-Ray BDP-83 - has anybody fitted new clocks?Hide this!Advertise here!
Oppo 980 psu lionking7 Digital Source 5 19th March 2010 06:37 AM
oppo dv980h vs marantz dv3002 joshuajoshua Digital Source 0 11th February 2008 07:13 PM
Oppo 970 anyone mod. yours? palchiu Digital Source 4 2nd September 2006 10:11 AM
Relationship between master clocks, system clocks, and audio freqs Garbz Digital Source 10 14th March 2006 03:02 PM
Any one fitted a superclock to a Marantz SA8260 and how frank2395 Digital Source 0 28th June 2005 12:23 PM
