Pioneer CLD-919, disc recognize failure - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th December 2009, 03:24 PM   #1
wmincy is offline wmincy  Malaysia
Default Pioneer CLD-919, disc recognize failure
I got a Pioneer CLD-919 Laser Disc Player which stopped reading disc.
I checked for the laser pick-up whether it is defected or not, however I can still notice the red spot and up-and-down of the lens, just like a CD player does when you switch it on. So I might think the laser won't be the cause of the problem. Nevertheless, I saw a LED like component on the pick-up assembly, I might guess its function as to detect the presence of disc.
But I can't see any light (maybe red light), could this LED like component a IR emitter? or this is exactly a LED but in this case burnt or broken?
Is there anyone who can give this an answer, advice? thank you.
the fever of DIY HI-FI will NEVER be cured !!!!
Old 8th December 2009, 07:34 AM   #2
The other device is a tilt sensor. This is used only for laserdisc playback, and senses the slight sag of the heavy 12" disc & allows the player to tilt the laser to the precise angle to prevent video crosstalk. I'm afraid you are fairly likely to have a bad laser, although, if it happened suddenly, with no previous symptoms, it could be a platter motor going bad, since this series senses motor drive current & stops play attempt if it sees the startup current on the motor escalating. Is it not playing ANY discs or can it play cd, dvd or laserdisc?
anyone recognize this amp? damage Car Audio 22 17th January 2009 12:39 PM
Converting CAL CL10 5 disc player to a single disc player stoolpigeon Digital Source 0 27th May 2007 02:25 PM
Attempting to diagnose pioneer PDR-05 cd recorder issue, won't recognize discs. 240z4u Digital Source 10 31st October 2006 12:59 AM
Pioneer DVL-919 no disc message for CD/LD only BobEllis Digital Source 0 8th December 2005 01:00 PM
Pioneer PDF-1009 (301 disc changer) service manual ? Helix Digital Source 0 25th January 2003 05:11 PM
Copyright 1999-2017 diyAudio
