Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Difference between Audiolab 8000CD & CDE
Old 12th January 2013, 05:54 PM   #11
HimeshP is offline HimeshP  United Kingdom
Default Audiolab 800CDE
Originally Posted by JohnW View Post
Hi Contax,
Yes, it’s a design issue internal to the Philips 8051 - they can under certain conditions wipe there own internal Memory!!! really useful! So most likely its memory’s been overwritten.
To prevent overwrite; the modification was to replace the series termination resistor inline with the MCU clock input with a 0805 100pF capacitor (or might have been 0603).
If you send me your front panel, I can reprogram it – or do you have an 8051 programmer – I could send you the hex file…
John
Hi John!
I hope you are well
I was reading up on this, as I have an Audiolab 8000CDE!
I have the following system: Audiolab 8000CDE (transport) --> MDAC --> HPA 200 Fidelity Audio Headphone Amplifier --> AKG K702/HD650.
I called Audiolab to ask what they can do with it - they mentioned they can take it in, improve the PSU and upgrade the software for £200 approx.
I also contacted the gentleman who built my headphone amplifier - Brent from Fidelity Audio - great guy- he mentioned that he could also conduct upgrades for the 8000CDE particular to the power supply and servo section. I'm unsure about the clock. However, he has a website which I'm sure you are aware of:
Fidelity Audio : C3 Low Jitter Premium clock Micro clock 2 dual output for squeezeboxes
Fidelity Audio : clock power supplies psu
So I'm unsure how to go about this as I only use the CDE as a transport. I am waiting for the MPAX and or other things to go with the rest of my system but I feel for now the Achilles heal needs to be attended to which is the CDE.
Please do let me know if you can advise in any way - it would be great to hear what you would do here.
Thanks.
Himes
Old 15th March 2013, 09:49 PM   #12
contax is offline contax  Spain
Originally Posted by HimeshP View Post
Hi John!
I hope you are well
Thanks.
Himes
Hello HimesP,
The Audiolab CDE and the CD share the same power supply PCB. The D/A PCB and the CD mechanism&servo are also the same. The control&display board are different.
The only difference, in the PSU PCB, is the Audiolab CD has 2 trafos, 1 for the digital section and 1 for the analogic section. The Audiolab CDE has 1 trasnformer with 2 secondaries. If you are using the CDE as a transport, my suggestion is you shouldn't waste your money improving the PSU.
Best regards
Old 2nd May 2013, 08:48 AM   #13
DIALDONSERVICIO is offline DIALDONSERVICIO  Spain
Default AUDIOLAB 8000CDE
Hi, I´m an AUDIOLAB 8000CDE's owner that it doesn´t work, I think I´ve got the same problem than Conrad and I think that i´m able to program it with the Flash Magic, but I need the Hex file.
Could you help me to get it??? and do I have to do any special to set the Flash Magic?? I will use an ISP programmer.
Thank you very much.
best regards.
Old 10th February 2016, 03:50 PM   #14
Tancrède is offline Tancrède  Canada
If i can understand, there is no good Cd player on this planet.......
Difference between Audiolab 8000CD & CDEHide this!Advertise here!
audiolab amps audiolabtower Solid State 2 13th January 2009 07:51 PM
Marantz CD63 vs Audiolab 8000CD jazzdude Digital Source 7 1st October 2007 06:04 PM
What is the difference between 3 series of Audiolab 8000A? ken1967 Solid State 4 25th December 2006 08:20 AM
Audiolab diy guy Solid State 0 29th April 2005 08:39 AM
PC Audiolab AuroraB Everything Else 0 25th August 2001 06:53 PM
Copyright ©1999-2017 diyAudio
