Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th November 2009, 09:33 PM   #1
Default Do the SAA7210 was much better than the SAA7000 ?
Hello
Do the SAA7210 was much better and with less jitter than the old SAA7000 ?
I have found a perfectly good working Sherwood CDP 310R cd player, it have a CDM2/10 and the same circuit than the Philips CD150 and CD350 cd players, it use a TDA 1540 Dac (14 bit) and use the SAA7010, SAA7020, SAA7000 and SAA7030.
I would use, in that Sherwood, a TDA1541A, in non-OS, if the SAA7000 would be as good than the SAA7210.
Thank
Bye
Gaetan
Old 28th November 2009, 06:37 PM   #2
oshifis is offline oshifis  Hungary
I have done it in a Marantz CD-84 with an external clock.
Old 28th November 2009, 09:09 PM   #3
Hello
How does it sound ?
Did you compared it to modified cd players using SAA7210 in non-os ?
Thank
Bye
Gaetan
Old 29th November 2009, 06:45 PM   #4
I could not realistically compare because there were two different players, one with SAA70xx family modified from TDA1540P to TDA1541A, the other with SAA7210/7220 with TDA1541A. The supporting circuitry (PSU, clock, analog part, etc.) is completely different, so any comparison would be misleading. I am not even sure if the TDA1541A is better than the TDA1540P.
Old 29th November 2009, 07:22 PM   #5
Hello
TDA1540 as good as the TDA1541 ? , maby.
Since the TDA1540 are only 14 bit, they use the SAA7030 filter and noises shaping to give some kind of 16 bit.
But I've read few comment saying that TDA1540 was sound very good.
Thank
Bye
Gaetan
Old 12th January 2010, 06:41 AM   #6
Hello
After recaping the CDM2/10 pcboard and checking the laser output power, etc..., I decided to give a try to that Sherwood cd player and to it's TDA 1540 14 bit Dac.
After listening few good cd, I found out that a TDA 1540 14 bit Dac sound much better than I was expect, it sound very good.
So a friend of mine will have that Sherwood cd player to go with his Crimson amp.
Bye
Gaetan
Old 12th January 2010, 01:47 PM   #7
Does the Sherwood have ceramic or plastic TDA1540 (ceramic=D, plastic=P)? I heard the 1st generation ceramic chip sounds really superb, but it is very rare.
Old 13th January 2010, 02:40 AM   #8
Hello oshifis
It's a P for plastic.
I have test it with a 1000 hz -60 db Verany test cd, and it have arround -47 db of distortion.
Bye
Gaetan
SPDIF Output from SAA7020, SAA7000 lscangus Digital Source 75 29th October 2010 08:10 PM
Saa7000 rfbrw Digital Source 31 19th December 2009 04:48 PM
SAA7000 chipset Duo Digital Source 4 20th February 2008 05:28 PM
Possible to connect something to a SAA7000 ? 00940 Digital Source 8 26th May 2006 08:12 AM
Page generated in 0.08966 seconds (77.53% PHP - 22.47% MySQL) with 11 queries
