Rotel RCD-855 stopped working - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th November 2009, 08:29 PM   #1
Mr DNA is offline Mr DNA  United Kingdom
Default Rotel RCD-855 stopped working
Hi everyone
I have a Rotel RCD-855 which up until recently was working fine. Once day it was playing a CD happily and then it stopped working. As I have absolutely no idea about electronics all I have been able to do is change the fuse. I have taken the top off and noticed that although nothing happens when I switch it on, it makes a short whirring type noise when powering off.
Anyway if anyone has any idea what I could I would be very grateful as I would rather not get rid of it. I must emphasise again I am clueless when it comes to stuff like this. Sorry.
Phil
Old 26th November 2009, 05:19 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
I know this player (I've repaired a couple before), and for troubleshooting they're easier in some ways than an average Philips player.
The symptoms you describe don't point to anything in particular, so the first thing to do is check the power supply voltages. There are at least six voltages you'll need to test, +5, -5, +10, -10, +15 and -15. You may want to remove the laser mechanism while you test it, as the best places to measure some of those voltages are right under it. Make sure you take anti-static precautions.
It's a nice player, so if you don't feel confident repairing it yourself, it's worth sending it somewhere.
Anton
Old 26th November 2009, 08:33 AM   #3
Mooly's Avatar
Did it actually fail while playing a disc ? that's unusual.
Does all the display etc light up OK and the tray go in and out correctly.
Does this model have loading belts on the drawer. The whirring you hear may be the loading motor trying to complete the load cycle and failing because the belt is slipping.
Something like that may be the most likely.
Old 26th November 2009, 03:49 PM   #4
Thanks for your replies.
It did fail with a disc in which I have managed to get out now. There are no lights and nothing at all happens except for the short whirring noise. There is a belt (sorry a bit vague. It is back together now). Regarding the voltages I have no idea how to do that. As I said, complete novice.
If I end up getting a replacement, can you make any recommendations. Want to spend up to 50 and happy to buy second hand.
Phil
Old 26th November 2009, 08:23 PM   #5
amc184's Avatar
These players use a standard CDM-4/19 loader mech, so even if the belt, drive gear or any other part of it is worn out, it should still function fine.
One of the main issues I have found with these players before is really poor quality soldering. If you're confident with a soldering iron, you can resolder the joints in the PSU area, which might fix it.
Otherwise, don't throw it away, post it on the swap meet forum. It should be an easy fix for someone who knows their way round a CD player. I'd be keen if you weren't on the other side of the world!
Old 26th November 2009, 08:26 PM   #6
tubenut is offline tubenut  South Africa
tubenut's Avatar
No lights does sound like a psu fault.
Another fault with these players (though the display would work) are two transistors below the mechanism part of the motor control aFAIR. If these failed, the motor locks hard and you can not turn it by hand when powered up.
Guillaume
Croak Audio Exploration
Cambridge Audio A3i stopped working... Franne500 Solid State 1 1st May 2008 03:46 PM
el84 1 channel stopped working help eddiedavies Tubes / Valves 5 2nd April 2007 12:32 PM
Advice on fixing an old amp that has just stopped working paulspencer Solid State 2 6th March 2007 06:39 AM
HELP! My remote volume control stopped working! :( paulspencer Analog Line Level 14 15th October 2006 05:34 AM
pinnacle 850 stopped working jamesj2 Multi-Way 1 14th February 2005 10:48 AM
Copyright 1999-2017 diyAudio
