| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
![]() I was wondering if there is any way how to split a digital source signal (DTS) into a dedicated digital signal like digital output for center speaker, digital output for subwoofer and digital output for front and rear. Has anyone done this before? Regards, Remco |
#2 |
It may be possible but it would be far from simple. You would need IEC61937 Pt 5, which covers non-linear PCM, specifically DTS, over IEC60958 aka SPDIF, to confirm it. But having split DTS datastream, how would you then go about decoding each pair of channels ?
#3 |
Grab an Audigy2 sound card. It has 3 SPDIF outputs in the digital out jack (you need a 3 ring jack). Decode with that card a DTS signal (they use to have it in the drivers for WinXP, Vista, I don't know for Win7, if not, use a software player that decodes DTS) and you will have 3 stereo PCM streams.
Or on a regular DTS decoder with analogic out (DVD player, digital receiver) - you will have at the DAC inputs 3 sets of i2s signals. You need to grab those and input them in 3 SPDIF encoders. To decode DTS in the six digital channels you need a licensed device... |
#4 |
Should a linux PC be your DTS source, splitting to individual channels is rather simple. If you mean a dedicated box with SPDIF input for DTS and 3/6 SPDIF outputs for PCM, it is also feasible using a linux PC, but significantly more complicated.
#5 |
Thanks!
This helps a lot! Remco |
| Y-cable for digital signals | Ryssen | Digital Line Level | 2 | 9th November 2009 11:25 PM |
| CDROM Digital Signals | glt | Digital Source | 0 | 2nd December 2008 08:16 AM |
| Splitting line level audio signals | squowse | Everything Else | 0 | 19th August 2006 03:21 PM |
| Splitting Digital Audio | soundNERD | Digital Source | 0 | 18th March 2006 12:59 PM |
| splitting a digital signal | bser | Digital Source | 4 | 26th October 2005 05:43 PM |
