| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I just finished building my CS8414 / TDA1541A non-os dac with ECC99 tube output-stage.. It sounds excellent but I would like to implement Elso's asynchronous reclocking because of the cs8414's relatively high jitter (200psRMS!)... but instead of building the clock section from Elso's schematic, can I just hook up the flip-flops to a clock module (oscillator)?
I believe Lesha did something like this here: http://users.podolsk.ru/boga/Images/DAC_DigR.gif The space inside my enclosure is tight so if I can just use a module, that would be great. I will post pics of my dac as soon as get my digital camera back.. |
#2 |
diyAudio Moderator Emeritus
Make that a low jitter module ( not a type for computer use ) and you'll be fine. Please check specs before you buy or buy a good one straight away like Guido Tent's XO module. 3 ps jitter will do !
It's only audio |
#3 |
I successfully implement the assyn. reclocking with normal 50mhz metal can oscillator with fairly good result. Haven't try Guido Xo or Elso'S 100mhz assyn. clock though. Shoud give better result i believe.
Toni |
#4 |
The purpose of reclocking is to lower the jitter. Standard modules maybe have lower jitter than SPDIF/CS8412 alltogether but a real low jitter module is the optimum of course.
It's only audio |
#5 |
Thanks for the replies! but now i have another question:
Does an oscillator module produce lower jitter or does a crystal in a clock like Elso's produce lower jitter? or are they so close that the difference is inaudible?? |
#6 | |
There is no unique answer as it lies in the design of both units and their power supplies. I did test (measure and listen to) over 30 modules, 28 of them are lousy. They all sound different anyhow. regards |
#7 |
I did test (measure and listen to) over 30 modules, 28 of them are lousy. They all sound different anyhow. ----------------------------------------------- Audiocom in UK claims they have a superior clock by not using an XO but a high frequency sine wave generator and then having the tops loped off - and old sine/sq wave generator technique. The price is rather, no too high. Any comments, anyone? |
#8 |
Banned
First, you start with a very high-Q circuit......and a very quiet power supply.
A friend who works for a crystal house is not at all impressed by the above mentioned clock. Jocko |
#9 | |
Banned
| How to reclock CDPro2? | cartman | Digital Line Level | 1 | 5th May 2009 07:52 PM |
| Use of a Ribidum Oscillator as refrence oscillator in a DAC | Mark A. Gulbrandsen | Digital Line Level | 18 | 2nd January 2009 09:57 PM |
| About a reclock for a dac | gaetan8888 | Digital Source | 0 | 28th October 2008 05:49 AM |
| does AES/EBU help if i implement reclock? | garbage | Digital Source | 44 | 15th September 2005 03:20 PM |
| Page generated in 0.11033 seconds (81.74% PHP - 18.26% MySQL) with 10 queries |
