Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th November 2009, 07:12 PM   #1
nad is offline nad  United Kingdom
Default Help to 'better' output schematic??
Hello,
Here's a simple schematic of my opamp output.
Can anyone suggest any changes for the better? The resistors are the standard 5% type so I assume swapping them for 0.1% RC55Y's would be a start?. Going on the 'less in the path' approach; do I need them all? can I remove a couple and only have 1? if so, what value would be ideal?
I removed all the resistors at one stage and the output became far to mellow so back in they went.
The caps were removed at another stage but it seemed to lack something, although I'm unsure what, So they went back in too.
I know black gates would be good but I'm looking into plastic film. There's a bit of space so it wouldn't be a problem. Anyone suggest a value/brand of plastic cap to replace the ZA??
Thanks in advance,
Ant
Old 11th November 2009, 08:28 PM   #2
Did it Himself
richie00boy's Avatar
Not sure why the 4k7 parallel with 75R is there, was there a muting circuit that you have now removed?
It's pointless using 0.1% tolerance resistors for this application.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 11th November 2009, 09:30 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Why do you have to a cap in the first place? Where does this signal go? What is your load?
/Per-Anders (my first name) or P-A as my friends call me
Old 11th November 2009, 09:35 PM   #4
Banned
An electrolytic cap... hmm, I don't know. Better use a space-saving Wima MKS2 4.7uF 63V, for instance.
Also I'd remove all those resistors and connect the capacitor to the output with something like 100 ohm.
Old 11th November 2009, 10:29 PM   #5
Correct, I've removed the muting circuit. Why pointless?
Old 11th November 2009, 10:30 PM   #6
I pressume it's a dc blocking cap?
Old 11th November 2009, 10:39 PM   #7
A polyester cap? possibly. 1/4w carbon 100 ohm?
Old 11th November 2009, 10:44 PM   #8
Did it Himself
OK the 4k7 was part of the muting circuit. You can get rid of everything and just use a 47 ohm 1/4 watt 1% metal film resistor and 47uF or so cap. Or if your input stage it is connecting to has a DC blocking cap you can remove this one.
0.1% tolerance resistors are pointless in this application because they don't affect the signal level to any real degree.
Old 11th November 2009, 10:48 PM   #9
Thanks,
Andrea (post above) recommends a 100R, which do I go for???
Old 11th November 2009, 10:53 PM   #10
Banned
If you want it small enough to fit the circuit, yes. I'm using the same Wima caps I've suggested (on a DAC's output) and I find them to be inaudible in the signal path.
You could use a 100 ohm (or also 200 ohm) 1/4W metal film resistor..
ML 27 output problem/ schematic quest Corvus corax Solid State 0 20th February 2008 05:43 AM
Can you suggest a schematic were i can use this FET into the output? destroyer X Solid State 50 6th January 2008 07:05 AM
t-amp output schematic jkeny Class D 3 28th July 2005 01:25 AM
JVC XL-V1100 output stage schematic ? Bernhard Digital Source 0 7th April 2005 08:58 PM
Output current of this CAT SL-1 schematic ? Tea Tubes / Valves 1 14th February 2005 01:23 PM
Page generated in 0.12591 seconds (78.12% PHP - 21.88% MySQL) with 11 queries
