| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Another question for any helpers out there......
Does anyone know if it is common practice when fitting any type/brand of ugraded clock to remove and jumper the 2 associated ceramic capacitors leading to earth from the old oscillators legs and also remove the parallel/series resistor? Thank you |
#2 |
The original capacitors are there as load specified for oscillation at the particular crystal frequency. If you are injecting a clock signal there is no need for these components anymore. If you are making your own oscillator you will need proper support components for your new crystal, specified by the manufacturer. Often these values will need trimmed for Exact operating frequency, and using the wrong ones will send you way out of the ballpark.
#3 | |
Thanks again Ant |
#4 |
I don't know what you're modifying. I can't even tell you which pin to tie the TCXO output to. You should have some info on the IC that you're externally clocking. The behavior (of a possibly disabled) internal oscillator will be described in the datasheet.
#5 | |
Can't find anything on the old oscillator (WIN 16.934 MHZ (12PF)) either. Thanks Last edited by nad; 9th November 2009 at 09:01 PM. |
#6 |
Do you have a schematic for your NAD unit or know the number of the IC you're feeding a new clock? Maybe someone on here knows about generic external clocking "protocol", but I can only help with manufacturers data.
#7 | |
I dont have the schematic, although I'm desperately in need of it. |
#8 |
#9 | |
It's a Toshiba TC94A54MFG 001 0725HBL 981968 Last edited by nad; 9th November 2009 at 09:34 PM. |
#10 |
rats
That's an old IC. I can't get data on that, so I can't even tell you which pin is the input or output of the internal osc. You'll need someone that knows. |
| Marantz CD5400 clock replacement | 4real | Digital Source | 83 | 11th March 2006 09:53 AM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 08:18 PM |
| Clock replacement for Philips SACD1000 | Hercules | Digital Source | 12 | 27th November 2004 12:56 PM |
| Audiocom clock vs. LC Audio clock | KevinLee | Digital Source | 22 | 26th July 2004 02:29 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 02:20 PM |
| Page generated in 0.12809 seconds (74.56% PHP - 25.44% MySQL) with 10 queries |
