| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
Can anyone help me?? I have a dikits.com.hk TCXO clock kit. It's all populated and ready to go in but I have no 12vac in the CDp , it states you can use direct 5vdc, anyone know how I should wire it at to 5vdc?? Do I remove/jumper the rectifier and go directly? Thanks Last edited by nad; 7th November 2009 at 03:47 PM. |
#2 |
Seems if it's not a CD63 nobody is interested?????
#3 |
Probably more likely because this is an obscure kit that isn't well supported.
Personally, I wouldn't connect 5VDC directly to it, as you'll lose any benefit the clock's power supply would have afforded you. How you'd connect is really depends on what voltages are available inside your CD player. The power supply is designed to regulate about 16.5VDC (regulated 12VAC), so if your player has a 15VDC supply, that may suit. If you post the values of the two resistors connected to each LM317 regulator, I'll be able to tell you what range of voltages is suitable. But to be honest, the best way to use the clock is with its own 12V transformer, like the designer intended. Add a small 240V to 12V transformer inside the case. |
#4 |
I'm going to go the route Wu (diykits) intended.
The only problem I have is I'm new to electronics and I know I'll need a transformer, but which one is the question? I've been looking for a 12v ac toroidal but see there are primary/secondary windings, how do you wire them for 12v ac out? Can anyone help? I'll be purchasing it from farnell so if anyone can point me at a specific item on the site (item no??) then that would be great. Thank you |
#5 |
Farnell product number 9530231 looks good. To wire this one up, you'd need to make the following connections:
Primaries: Brown lead to Phase Blue lead to Neutral Connect violet and gray leads together Secondaries: Red lead to either of the 12VAC terminals on the PCB Orange lead to the other 12VAC terminal on the PCB Connect black and yellow leads together Also, as with any mains electricity project, there are many rules to follow, such as: - There must be a fuse in mains supply to the transformer. A fuse value of 100mA would be about right. - If the CD player you are installing this into is double insulated, make sure your work is too. - Make sure you don't form a shorted winding with the transformer. |
#6 | |
#7 |
No problem.
If your new to electronics, it might be best to post some photos of your install before you apply power to it, so others can check that it looks alright. Anton |
#8 |
#9 | |
-Double insulated? I'm unsure of what you mean, sorry. -Shorted winding? is that wired incorrectly? Thanks |
#10 |
Okay, put the fuse in as per the attached diagram. A secondary fuse is not necessary.
There are two types of appliance, grounded and double insulated. With grounded appliances the chassis is connected to ground, and the power cord will have a ground pin (three pins total). Double insulated appliances are not grounded, and will only have a two pin power cord. They use two layers of insulation to ensure they remain safe. If your CD player is double insulated, and a lot are, you need to put two layers of insulation on all the 240VAC cables and fittings you add to make sure the player will still be safe after you modify it. A shorted winding is formed when you somehow make a conductive loop through the middle and completely around the toroid. The transformer will get very hot, then very broken. See diagram for example. |
| www.diykits.com.hk stepped volume control ... any good? | kvk | Tubes / Valves | 19 | 23rd April 2008 09:10 PM |
| My CD Clock - the "Kwok Clock" | kwokm | Digital Source | 13 | 10th September 2006 01:34 PM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 08:18 PM |
| Audiocom clock vs. LC Audio clock | KevinLee | Digital Source | 22 | 26th July 2004 02:29 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 02:20 PM |
| Page generated in 0.11820 seconds (79.71% PHP - 20.29% MySQL) with 11 queries |
