| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 | |
I shouln't really be messing with stuff I have no idea about. Shame, it keeps costing more money to fix. I've now spent 3 times the amount of the initial cost of the brand new player on bits and bobs and all I've gained is a non worker. Boooo. |
#32 |
I'm in need of testing the output of the IC, there's little info on the net apart from this pdf here: http://www.toshiba.com/taec/componen...94A5460MFG.pdf
As I have no output, do I need to check pins 57 to 60?? and/or any others to see if I've cream crackered the IC??? Thanks |
#33 |
I just did a quick test on my player and found the strangest thing........ When the player is on, the output turns to ground, but when the board is removed with no power, it's not!
What the hell is going on?????? |
#34 |
Anyone?
#35 |
Fantastic...........................
After all that it was a silly little break in the circuit. The circuit was broken from the Toshiba IC on the MCLK track to the dac where the old oscillator sat, oops, too much heat. Good stuff, so after 6 weeks, 67 replacement caps, 3 Class D regs, opamps, CMC silver rca's, alot of dampening, a re-wire, a clock kit, a 12v toroidal, reels of mundorf solder, removal of un-needed bits, burnt fingers and alot of shouting, it's finished and the brucey bonus is............. it sounds great! There's a photo attached if anyone's interested. Chow fa now |
#36 |
I think we've all had those moments.. Glad you found the problem.
What do you think of this external clock as compared to the original crystal/internal oscillator?
www.kta-hifi.net |
#37 | |
Chuffed! |
#38 |
RIP
I knew you would get it straightened out, you now are a bona fide, fearless, DIY solder slinging crazy man, just like the rest of us.
Best regards, Bill |
#39 |
#40 |
Me too..
![]() At some point I'll have to check out that oscillator kit for my shigaclone..
www.kta-hifi.net |
| www.diykits.com.hk stepped volume control ... any good? | kvk | Tubes / Valves | 19 | 23rd April 2008 09:10 PM |
| My CD Clock - the "Kwok Clock" | kwokm | Digital Source | 13 | 10th September 2006 01:34 PM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 08:18 PM |
| Audiocom clock vs. LC Audio clock | KevinLee | Digital Source | 22 | 26th July 2004 02:29 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 02:20 PM |
| Page generated in 0.10542 seconds (78.76% PHP - 21.24% MySQL) with 11 queries |
