| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
What is going on?????
The clock is powered by a 12v toroidal, the tcxo is getting 5vdc as it should, I've removed the 2 old oscillator caps to ground and the resistor, theres no solder splashes or dodgy soldering and the in/out is correct but when I power the player (NAD C515BEE) the transport goes crazy. Its spinning eratically and clicking as if it doesn't know what to do............ Any suggestions?? Anyone had problems with their diykits clock?? |
#22 |
RIP
One question, where have you connected the new clock ground.
#23 |
#24 |
RIP
The return is the ground, it is the ground plane on your new clock circuit. Foreign translations sometimes aren't clear. The return should be connected to a ground point close to the chip you are feeding the clock to, or the signal can get into other circuits.
Where do you have the return connected now. |
#25 | |
#26 |
RIP
No, the new clock is self contained, it takes no input from the chip. Connect the clock output to the Xin and the return to a ground near the chip. That's it. I'm hoping nothing is damaged.
I tried to look at the clock on their website but the page wont load. Last edited by Bill Fuss; 14th November 2009 at 01:57 PM. |
#27 | |
Thanks for that, the disc reads perfect and the toc is correct. The only problem now is I have no output???? I'll try rectify that in a mo............ Ta |
#28 |
Well...............
The clock is working perfectly and spinning the disc and reading it correctly but there is now no output. I've checked nearly everything apart from the signal from the Toshiba TC94A54MFG-001 IC to the dac. How do I do this?? have I killed the toshiba?? Ta |
#29 |
RIP
I'm definitely not a genius. It might be toast, but probably not.
I could not find the chip's datasheet, but it is supposed to have built in DA converters. If you can find those output pins you could check it with a dmm. If you have an outboard DAC unit you could see if the spdif output is functioning. Otherwise, it will take an o-scope. Also worth noting, the chip is 3.3v,the clock is 5v. Check with the clock seller about the possible need for reducing the clock signal voltage. Good luck, Bill |
#30 |
RIP
Also, if you still have the original parts you could reinstall them and check the operation before you go any further.
| www.diykits.com.hk stepped volume control ... any good? | kvk | Tubes / Valves | 19 | 23rd April 2008 09:10 PM |
| My CD Clock - the "Kwok Clock" | kwokm | Digital Source | 13 | 10th September 2006 01:34 PM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 08:18 PM |
| Audiocom clock vs. LC Audio clock | KevinLee | Digital Source | 22 | 26th July 2004 02:29 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 02:20 PM |
| Page generated in 0.12946 seconds (77.72% PHP - 22.28% MySQL) with 11 queries |
