Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th November 2009, 11:22 PM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Help on reconfiguring PCM1738 dual dif outputs please
Hey guys, I have a nice sounding balanced input discrete Transimpedance I/V -output amp and I would like to slot it in before all the opamps in this circuit, is it possible to parallel up the dual dif outputs to give me balanced outputs?
I-out positives together and I-out negatives together or another way?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 5th November 2009, 05:02 AM   #2
georgehifi's Avatar
I understand from the other place I can just parrallel the I-outL+ & I-outR+ and then I-outL- & I-outR- then this gives me balanced output instead of dual dif.
But what happens to Vcom2 that goes to Pin3 of all the LT1357's
(below is a single channel magnification) if you need to press the X in the bottom left of the first attachment and this to expand it more.
Cheers George
Old 5th November 2009, 05:21 AM   #3
kevinkr's Avatar
Cheers George
Hi George,
I'm doing something similar to what you describe in my diy dac. Basically I am running a pair of PCM1794A in mono mode, and summing the output currents prior to the differential transimpedance amplifier I am using. Note in the case of the 179x family when you run in mono mode the polarities of one of the differential output pairs is swapped depending on what channel you have selected to output - in my case I just cross connect them to maintain the proper polarity. Since the transimpedance amplifier has close to 0 input impedance there is no interaction between the dacs and the currents just sum as you would expect. Sounds great and is very simple compared to some of the hare-brained schemes I have seen.
www.kta-hifi.net
Old 5th November 2009, 05:27 AM   #4
kevinkr's Avatar
Cheers George
Hi George,
I believe Vcom2 is just a buffered dc voltage which is probably about 1/2 the reference output voltage (1/2 FS) that is fed to the I/V converter in order to allow for the cancelation of the dc offset present in the output of this converter. Depending on the common mode range of your transimpedance amplifier you might be able to ignore it, otherwise you will need to account for the offset at the input.
Edit: This is a unipolar dac which means signal baseline is about half of the analog supply voltage and applying 1/2 the reference voltage to the reference junction (+) of the I/V converter makes the dc component of the dac output common mode, the input cmrr then cancels the dc component leaving only the ac signal. If your transimpedance amplifier is truly differential and has a sufficient input CMR it should reject the dc component and you can probably safely ignore the Vcom2.
www.kta-hifi.net
Old 5th November 2009, 06:22 AM   #5
georgehifi's Avatar
Thanks Kevin, maybe Vom 2 can go to input ground without link 4 being bridged, can that be done?
Here is my Transimpedance board with filter dc servo and class a single ended output, you may reconize it.
Cheers George
Old 5th November 2009, 05:14 PM   #6
kevinkr's Avatar
Cheers George
Hi George,
I don't believe that Vcom2 should be tied to anything in this case, tying it to ground will short it out. (You might even destroy the dac ic as these pins are not usually short circuit protected.)
FWIW I think this design was intended to accomodate a large variety of dac ICs and has sufficient input cmr to work ok with the offset.
www.kta-hifi.net
Old 5th November 2009, 08:03 PM   #7
georgehifi's Avatar
Sorry Kevin have a close look at the diagram of the Transimpedance amp it's not really ground if you don't link no. 4.
Cheers George
Old 5th November 2009, 09:36 PM   #8
kevinkr's Avatar
Cheers George
Actually as long as you don't link connection 4 you do want to connect Vcom2 there - this provides the common mode reference to the input stage and based on what I see should properly compensate for the common mode dc on the input diff pair.
The numbers are bit hard to read is all.
www.kta-hifi.net
Old 5th November 2009, 10:16 PM   #9
georgehifi's Avatar
Click on the attachment (bigger) then click on the X in the bottom left (much bigger)
So this looks the goods for the vcom2 connection.
So I parallel the 2 - outputs and the 2 +outputs this then gives me -&+ balanced outputs at double the current?
I may have a problem as the data of the PCM1738 says it has 2.45mA output current, paralleled gives almost 5mA?
My Transimpedance board with 4 x PCM56 outputs (4mA per channel) from my Wadia dac just clipped at 0dbF sinewave from my test discs. I managed to drop this to just below clipping at 0dbF with a 100ohm series resistance on the input of the Transimpedance board.
But with the 5mA of the doubled PCM1738's this will need even more attenuation I think, I think I'm in trouble.
Cheers George
Old 6th November 2009, 10:38 PM   #10
georgehifi's Avatar
kevinkr, I'm going to try it next week, just making sure with you before I do with the attached diagram one channel only shown. (don't want to blow anything)
1: 2 x positive outputs of dac together go to + input of I/V
2: 2 x negative outputs of dac together go to - input of I/V
3 : vcom2 from dac goes to G of I/V link 4 NOT bridged.
Cheers George
Building a Preamp:Dual Outputs Question mourip Tubes / Valves 3 21st May 2006 08:19 PM
Need help!! with PCM1738 and uP code Audiopower Digital Source 11 15th May 2005 01:05 AM
PCM1738 or AD1853? bocka Digital Source 6 24th January 2004 10:44 AM
Dual outputs for Balanced Line Stage Preamp Zapped Pass Labs 6 2nd October 2003 07:36 PM
Dual Toroid outputs... Yoda Parts 5 27th September 2001 02:36 PM
Page generated in 0.13001 seconds (80.43% PHP - 19.57% MySQL) with 11 queries
