Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th November 2009, 04:43 PM   #31
jcx is online now jcx  United States
I see Mooly finally has found an important piece of the "puzzle"
the circuit is a fully differential amplifier made with the dual op amp and a fully differential multiple feedback low pass filter
single fully differential op amps like THS4130 are popular for high speed signal processing like A/DSL
but you will find fully differential op amps also include a a output common mode servo on the chip
http://focus.ti.com/lit/an/slyt165/slyt165.pdf
the posted circuit fixes the outputs to be symetric with respect to gnd - which means the typical mid supply offset of the DAC outputs causes DC current to be drawn from the DAC +/- output buffers - not always a good thing
using just one side of the differential output you are relying on lots of components ratio matching for common mode rejection/differential-to-single ended conversion accuracy
there can be stability issues using the 2 op amps from a dual to build the fully differential amp - the phase margin may not be high enough - especially with the odd internal compensation of the 5532
Old 6th November 2009, 04:53 PM   #32
It was said a the second post.
Originally Posted by SoNic_real_one View Post
That's the negative feedback. Instead of applying the neg feedback only on one input in an assymetrical way, they take the output, invert it and apply the feedback on positive input too. In this way the main Op-Amp has symetrical signal and impedances on the inputs. Maybe hepls with interferences via ground since it will isolate the ground plane, but I didn't tested nothing like that.
I would use the second half of a dual OpAmp for that.
Old 6th November 2009, 06:49 PM   #33
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Great stuff guys. Exactly what I hoping for, to learn about the circuit in question.
Old 21st December 2011, 04:11 PM   #34
gvelim is offline gvelim  United Kingdom
Originally Posted by Mooly View Post
I got interested in this and turned this up,
Differential Multiple Feedback Bessel Low Pass Filter
which is the same configuration. As I suspected earlier that second opamp is vital to the filter operation. The opamp circuit in the above link has both inverted and non inverted outputs.
You may also find the below article informative w/ relation to the thread topic
"A Differential Op-Amp Circuit Collection" : http://www.ti.com/lit/an/sloa064/sloa064.pdf
..."Proper operation of high-speed op-amps requires proper decoupling techniques. That does not mean a shotgun approach of using inexpensive 0.1-µF capacitors. Decoupling component selection should be based on the frequencies that need to be rejected, and the characteristics of the capacitors used at those frequencies"
bjt amplifier ciruit shaineice Solid State 0 26th December 2008 03:27 PM
do i REALLY need a crossover?? and an amp question. and an ohm question legendaryfrog Multi-Way 4 29th October 2006 01:39 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Linkwitz transform ciruit applied to midrange driver Beggar Multi-Way 6 8th August 2002 11:16 PM
Page generated in 0.08234 seconds (74.28% PHP - 25.72% MySQL) with 11 queries
