Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd November 2009, 11:19 PM   #1
nad is offline nad  United Kingdom
Default CD output L/R channels uneven
Hello,
My NAD C515BEE CD player seems to be outputting a slightly uneven left/right sound.
There seems to be plenty of punchy bass from the right but it's missing some high notes, where as the left channel seems to be missing some punch but has more top.
It's definately not the cables/speakers/positioning/amp as I've swapped, checked and checked again.
Anyone help me???
Old 4th November 2009, 07:48 AM   #2
UV101 is offline UV101  England
UV101's Avatar
probably a silly question, but is it the same on different cds?
Some recordings can give you these symptoms!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 4th November 2009, 05:55 PM   #3
Thanks, never thought it might be the cd. I'll try a variety tonight.
I'm going to make a test cd in duplicated stereo comprising of 20 second tracks of numerous frequencies ranging from around 40hz to 20khz in steps. That should let me know if each channel is producing the equal output. And if not, at least it'll tell me at what frequency there is a problem.
Old 5th November 2009, 05:45 AM   #4
kevinkr's Avatar
Watch out at frequencies beyond 5kHz or so that you do not damage your tweeters, they tend not to like high amplitude single tones which can quickly destroy the voice coil due to overheating. (In some cases just a few watts for a couple of minutes or less is enough to do it.)
Frankly anything above a few kHz is likely unnecessary for this test. This isn't the way I would do it unless I had no test equipment at my disposal.
www.kta-hifi.net
Old 6th November 2009, 08:11 AM   #5
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
If you have a DVM that reads reasonably accurately over the audio band (not all do) use that on AC volts to check the line outputs from the player with a test CD.
You can do the same test then across each speaker output but don't go over 2 or 3 volts rms.
Old 6th November 2009, 12:43 PM   #6
wwenze is offline wwenze  Singapore
...or you can create a 50Hz test clip.
Transformer with uneven ac out geminni Solid State 6 1st February 2008 06:52 AM
Uneven voltage on PS chipco3434 Power Supplies 11 22nd February 2006 03:10 PM
uneven output on my 206 carlos671 Digital Source 2 6th December 2005 04:10 PM
uneven wound 50w OT 2 ideas...? dud_wity Tubes / Valves 13 29th March 2004 01:54 PM
Increasing output channels of preamp. hugobross Solid State 19 6th February 2002 05:13 PM
Page generated in 0.08121 seconds (74.93% PHP - 25.07% MySQL) with 10 queries
