Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th October 2009, 08:08 PM   #1
Andypairo's Avatar
Default Teac WAP2200 : what's inside?
Hello,
did anybody open the Teac Wap2200 to see how can it be tweaked for better audio quality?
This streamer looks very interesting for various reasons:
-Remote with built in display
-Plays directly from USB storage, no need for a music server
-pretty low cost
The cons are (from what I can see):
-only optical SPDIF
-not the best audio quality
If the first issue looks easily solvable, a serious audio tweaking (clock slaving, IIS tapping) needs the knowledge of the inside.
So, before buying one, I'm asking if someone has already opened one and maybe knows which dac is used, or maybe can post some photos...
Ciao
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 16th October 2009, 08:26 PM   #2
guido is offline guido  Netherlands
guido's Avatar
Somebody already opened a wap4500 which i also have. Same thing with ethernet and wlan support. He changed the output caps (elco) with something better. Google for WAP4500 - Tuning.pdf. Some pictures in there too.
As for the DAC, it's a Wolfson WM8750BL. Not the greatest indeed. It's a codec (ADC/DAC with headphone amp).
I guess the 2200 is equal in that respect.
I'm thinking of integrating one into a diy dac, but i'm not shure it is possible (clock setup).
GuidoB
Old 16th October 2009, 09:04 PM   #3
Andypairo's Avatar
From what I can see the Wolfson codec uses a internal PLL to generate the needed frequencies starting from (generally) a multiple of 48kHz but it mostly depends on the actual implementation. I see 2 crystals on the left of the bigger photo but I can't see their frequencies. If one of them is multiple of 44.1kHz it means that the DSP "switches" the correct xtal and it might be possible to inject a external, low jitter clock.
As for I2S tapping, the DAC supports it along with other data formats, so it depends again from the actual implementation if it is possible to avoid SPDIF...
Ciao
Andrea
Old 16th October 2009, 10:35 PM   #4
guido's Avatar
Ciao
Andrea
I'm reading the datasheet too...
Question one, is the dac master or slave on the i2s signal. As the xtals are not near the dac, i'm now guessing it's slave mode. So than it's not interesting what clock is used for the dac's master clock. It's the clock of the dsp which generates the i2s signal which is of interest.
I'm not afraid if the signal itself is not i2s. Glue logic should be no problem. But i would also need to look at the sample rate as a pmd100 (the filter i have here for a dac) does not take 96kHz (55max). I would have to bypass the filter if the rate is higher than 48kHz i guess. More glue logic... Or downsample if i have 96kHz material.
Or still use spdif (still with the master clock in the dac) as it's output is 44.1 or 48 according to the manual. Makes me wonder if the dac would receive 96kHz with 96kHz material or also a downsampled version....
I'm currently putting all my CD's on my nas. At least that's all 44.1.
I guess i need a nice logic analyser for serial signals to check out the i2s signal (or whatever it is) and also the control signals to the dac. And then try material with different samplerates and number of bits. Or buy a Linn
GuidoB
Old 16th October 2009, 10:59 PM   #5
Andypairo's Avatar
I remember you 're using the PMD100 together with the TDA1541A (which is also my favourite DAC).
Of course "our" DAC is limited to 44.1/16bit but most of the "software" is 44.1/16. And for the DAC I guess that a 96k/24bit IIS stream is equivalent to a 2x oversampled 16 bit stream (further bits are ignored IIRC).
And I have a ES9008 on its way...
Ciao
Andrea
Old 16th October 2009, 11:24 PM   #6
guido's Avatar
Ciao
Andrea
I'm not using it at the moment as the (test) setup got unreliable. If you've seen the pictures of the insides of that 650 you know why
There is no DAC yet, but i'm working on one (or planned to). I have some output stages for a pcm63 setup (D1 and the old "tent" dac tube stage nearly finished) and enough pcm63's to build something. But as i'm now transfering to all music to harddisks, i stopped playing with cd players for now.
A Linn 24bit 88.2kHz flac testtrack plays fine on the WAP4500. It's 88.2kHz according to the remote, but what actually goes to the dac....
GuidoB
Old 17th October 2009, 12:06 PM   #7
EUVL is offline EUVL  Europe
I have a WAP2200. For playing music in the garden or in the kitchen without having to run mains cables, it is great. For audiophile use it can improve a bit.
The built-in DAC is not brilliant, and output level is low (limited by 5V supply voltage). Probably also with SMD decoupling caps (most likely ceramic MLCC). Digital (SPDIF) out is Toslink and not BNC. No I2S out direct. Power supply is switch mode. It consumes almost 1A at 5V. The thing gets really warm.
The uP has IMHO too many tasks to do -- get data from USB, decode various music formats (almost anything you can think of), talk to the remote with lots of complex information exchange both ways, stream data, ...... I doubt the data is still jitter free. MP3 fans would love it. To be fair I have only tried the analogue output and not (yet) Toslink.
My preferred solution is the QA550 SD player. Has everything I want, totally solid state, has I2S out on top of SPDIF, which as stock already sounds great with a simple TDA1543 (just quick and dirty test). Plan to test external clock and I2S reclocking. Need a few more months.
For price and features, the TEAC is hard to beat. If you can read German, there are tons of discussions here :
http://www.hifi-forum.de/viewthread-181-2427-1.html
And pictures of the PCB :
It's a very good consumer product, if you do not expect it to do anything high end.
Patrick
Old 17th October 2009, 03:07 PM   #8
Andypairo's Avatar
Patrick
I've also seen the QA550, but it lacks 2 of the wap's best features, i.e. the remote with LCD for comfortable browsing and support for something bigger than a SD card (even tough reading from ss source has its advantages...)
Thanks for the pics. For what I can see it has a 11,289MHz crystal, so there is the possibility that such clock is used to stream 44.1kHz data. This shoud be verifiable looking at the relative phase between it (:4) and MCLK. If the relative phase remains constant....
I am aware that the Wap is not high end, but I hope it is tweakable to become high end
Ciao
Andrea
Old 17th October 2009, 04:02 PM   #9
A SD card has up to 32GB. I doubt you have the stamina to listen for that long. If you want 1TB of music on one hard disk, feel free to try the WAP2200. With 5 X'tal on one PCB, I am not going to try to figure out what is syn to what.
The tuning in post #2 is just changing the decoupling cap. Doesn't get to the root. I guess better than no change.
Patrick
Old 17th October 2009, 05:08 PM   #10
guido's Avatar
The xtal on the bottom is called Y7, so there are enough x'tals... But looking at the xtals near the '04 there must be possiblities to feed a clock in. The biggest problem to me seems to do measurements on those tiny pins and tracks
I'm thinking about still using the spdif (48kHz max) connection and feeding the masterclock back in. Then i don't have to care about the interface between the dsp and dac and converting it. And on how to handle 96kHz material if that would go to the dac as 96kHz over the i2s. And there is optical isolation if i would include that in the clock feed.
The other xtal is 12.295 which is close to the theoretical 12.288, so i think it is the xtal for 48kHz material. As i don't have any 48kHz material i know of, i won't bother with that one.
No SD for me. I have all my media at one nas with a standard upnp/dlna server to serve my tv, computer, audio streamers or whatever in the future. And there are already high end options for music like Linn. I think more will follow.
Guess it's time for a screwdriver
GuidoB
Teac P70 Telstar Digital Source 0 25th February 2009 09:36 AM
Teac cd-5 olafi Digital Source 0 13th October 2008 11:50 PM
TEAC AG-5D HT Amp Help Anyone... GAgola Solid State 0 7th July 2008 02:23 PM
Teac d-500 DAC + Thanks Wheelieman Digital Source 1 13th July 2007 07:23 PM
Page generated in 0.15597 seconds (83.14% PHP - 16.86% MySQL) with 11 queries
