| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
#12 |
Not electrolytic. They are high precision 1% types, polyester or polystyrene I think. They are used in the servo feedback loops - where they make the player behave totally erratically, and in the de-emphasis network where they make an intermittent roaring sound.
Steerpike's Toybox |
#13 |
Thanks steerpike
#14 | |
#15 |
If its similar to the MKI version, there are 5 16v/33uF little blue radial elcos.
Mine was not reading disks, i replaced these 5 elco's with Sanyo Os-Con of the same value and the deck's as good as new now. This is a fairly well known problem given the age of the transport. Also, I beleive (as stated in a previous post) that the laser can be taken from a cdm4. You will need the SM and a scope to set it up properly tho'. Also, the lense in the original mech is glass and the 4/19 used a plastic one. I've don't think outright laser failiure is very common on these decks. Pic showing the caps on my transport
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
#16 | |
Eg., 3600pf you could make up from 3 x 1200pf in series, and 1200p is an easier value to find. And then if one of your 1200p is a bit on the high side, compensate by picking the others on the low side, so the total come to a good match.
#17 |
#18 |
I'm no authority, only going on what I read some time ago albeit I can't remember where. I've googled again and it does seem that the lense is glass not plastic (on CDM4/19 in any case). I stand corrected!
#19 |
Hello Steerpike,
Whats the best way to check polystyrene caps-can you use capacitance meter or do they usually break down with load? I have very little expeirence with polys & ceramics. Thanks Donald |
| WTB: CDM1 MkII | JMPires | Swap Meet | 1 | 15th October 2009 05:59 PM |
| CDM1 MkII gurus - need your help! | tonyptony | Digital Source | 18 | 1st June 2009 09:25 PM |
| CDM1 MKII Alignment woes | gto127 | Digital Source | 20 | 22nd March 2008 01:16 PM |
| Philips CDM1 MKII = CDM2?? | FC5687 | Digital Source | 2 | 4th July 2007 11:32 AM |
| Cdm1 Mkii? | Rotellian | Digital Source | 7 | 29th March 2004 09:16 PM |
| Page generated in 0.09601 seconds (82.66% PHP - 17.34% MySQL) with 11 queries |
