How Lampizator CD tube player sound? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th October 2009, 04:32 AM   #11
Pano is offline Pano  United States
Pano's Avatar
The Lampizator is an SRPP circuit, but with certain Russian tubes -6H6P. (6N6Pi) I have a set, but have not used them yet!
Lampizator page index
Old 17th October 2009, 06:21 AM   #12
dvb projekt's Avatar
i use the Lampizator Stage from Lukasz in my 4*TDA1541A DAC with outstanding results.
You could read it in THIS thread.
Best,
Oliver
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 17th October 2009, 06:08 PM   #13
CrazzyAbtTubes's Avatar
I have been contemplating what kind of caps I should use to replace the 14 220nF surface mount caps around the TDA1541A with, got any good suggestions? I hear that Nichicon Muse are good in the power supply, I have 2 Gold tune 10,000uF 71V caps salvaged from a Sony amp and 2 330uF 50V BG caps that I purchased a couple of years ago.
Old 17th October 2009, 09:31 PM   #14
Nikolas Ojala's Avatar
In my CD player (SONY CDP-XB930) there is a digital output, so if I wanted to try this, I think it would be best to leave the CD player as it is and build an external DAC unit with tube buffers. Right?
High-order harmonics are more offensive than low.
Old 18th October 2009, 02:09 AM   #15
tubo is offline tubo  Philippines
hi panomaniac,
i may be wrong! but i think the 6n6pi version should not be used only the 6n6p. link here
upgrade_noval_tubes_to_6H6P
Old 18th October 2009, 02:11 AM   #16
ive used it for my cs4397 dac with great results.
Old 18th October 2009, 02:55 AM   #17
Pano's Avatar
Well there is a lot of confusion on how this tube is called. As it's a Russian tube, it's marked in Cryllic. So to those of us who mostly read the latin alphabet, it looks like 6H6n
But that would actually translate as 6N6P in latin script. The last letter looks like an odd letter "n" in the latin alphabet, but it is P (Pi) in Cryllic. As in Greek. Π
I hope that makes sense!
Old 18th October 2009, 02:55 AM   #18
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Thanks all.
I thought this might have been a way to improve the sound of computer CDrom drives to use them as reasonable audio CD Drives.
I see now it is about improving audiophile CD drive systems.
Old 19th October 2009, 01:02 PM   #19
Akita is offline Akita  Malaysia
Hi again,
I have check with my scope on my player.
The left signal is taken from dac output and the right signal is taken from the rca after amplified by tube.
It look like the signal clipped just after the dac. Any idea how to fix it?
My cd player dac is TDA1549T.
Old 19th October 2009, 03:58 PM   #20
Originally Posted by TheGimp View Post
Thanks all.
I see your point, I actually have a bunch of old computer CDrom drives stashed away waiting to be Lampized or have their cheap output opa-amps removed for experimentation, but that may be for a more spacific thread yet to be created....
Cambridge 640C MK1 with balanced Tube output stage (Lampizator) Baraccuda Digital Source 0 27th December 2008 10:44 AM
Why does my CD player sound better then my PC? Jonasa Digital Source 19 14th November 2007 04:22 PM
Different sound for CD Tube Player liberty Tubes / Valves 3 29th March 2007 06:46 AM
DVD player with good sound 8969ko Digital Source 2 30th May 2005 02:06 PM
Sound of DVD Player Software fmak Digital Source 1 8th June 2003 05:59 PM
Copyright 1999-2017 diyAudio
