Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th July 2010, 09:43 PM   #371
Send a message via MSN to sq225917
dealxtreme.com
hoping to pick up some things.
Old 7th July 2010, 09:48 PM   #372
jkeny is offline jkeny  Ireland
Banned
Originally Posted by merlin el mago View Post
Thank you jkeny to share with use the tweak & to help me, where can buy your special batteries 3.3V because I want to compare:
-Salas V1.2 shunt regulator
-Erno Borbely series regulator
-Your batteries
A123 batteries but watch out for fakes & no I can't tell you if you find a link whether it's fake or not, sorry!
Old 8th July 2010, 11:33 AM   #373
merlin el mago's Avatar
Are these:
Manufacturer A123, 3.3V 1100mA
In Spain are available here:
http://shoptronica.net/740-bateria-l...0ma-18650.html
Old 8th July 2010, 11:35 AM   #374
Banned
I can't tell which are fakes & which are not - all I can do is point you to the manufacturer's site A123Systems :: Products
Old 8th July 2010, 11:51 AM   #375
Thanks jkeny, mine posted photo is from the site but in this web don't tell where to buy, for people not leaving in Spain can google searching "model aircraft flying" & pay attention to be sure looks like in the photo because as told jkeny there are fake copies green colored in e-bay.
Old 12th July 2010, 02:16 AM   #376
play458 is offline play458  Thailand
this good job thanks
Old 26th July 2010, 03:24 PM   #377
Default Clock up-grade
What about to change the clock for this:
Selectronic Web link:
Assembled & tested
SELECTRONIC ::: L'univers électronique :::
Kit
Photo kit
Or is waste time & money due to asynchronus mode TP Buffallo II?
Old 17th August 2010, 05:30 PM   #378
Default Hiface / EVO still "Clicking"
I just got the new EVO (and Hiface before) and there is still the same clicking between tracks. I tested the following configuration and slowly loose confidence that M2Tech will be able to solve it. They repied that it may come from some players or PC types, but I tested any configuration and still clicking:
Test Summary/Failure description
Symptom: Clicking when changing tracks (not within the track) only with KS& ASIO (not DS directsound)
Tested configurations:
Netbook (Windows 7 Starter, Dell Mini Inspiron 1012, Atom N450, 1.66GHz)
PC Desktop (XP Pro, Quadcore 4x3.4GHz)
Hiface / EVO (no difference in regard of clicking)
Hiface driver 1.0.3.140 & 1.0.3.141 (no big difference in regard of clicking)
Sample rates/resolution 44.1, 48, 96kHz, 16, 24, 32 bit (no difference in regard of clicking)
Mode: KS kernel streaming & ASIO (no difference in regard of clicking), DS direct sound worked fine
Foobar 1.0.2.1 & 1.0.3 , Media Monkey (no difference in regard of clicking)
Buffer length: 50ms....3000ms (no difference in regard of clicking)
DAC: Cambridge DAC Magic II & Harman Kardon AVR (no difference in regard of clicking via Hiface, direct to PC>DAC works)
Clicking: Netbook > Foobar > KS_Hiface > coax > DAC1
Clicking: Netbook > Foobar > ASIO_Hiface > coax > DAC1
Clicking: Netbook > Mediamonkey > ASIO_Hiface > coax > DAC1
OK: Netbook > Foobar > DS_Hiface > coax > DAC1
OK: Netbook > Foobar > KS_DACMagic direct > coax > DAC1
Clicking: Netbook > Foobar > KS_Hiface > coax > DAC2
Clicking: PC > Foobar > KS_Hiface > coax > DAC1
I think I tried almost any combination and replaced any component in the chain, so definitely the problem results from Hiface / EVO.
No other device (Roland Cakewalk UA 25EX, Behringer UCA 202, Cakewalk UA 1G, M-Audio Transit USB, ...) I tested till now showed that effect (all worked OK), so please try to fix that issue. In case you like me to test any configuration I did not test please let me know.
Littlesloth
Old 31st January 2011, 11:20 PM   #379
Any update on this?
My 2ct on this issue: I tried using the Winamp KS plugin v2.5 instead of the latest (v3.63) and it seems to reduce the amount of clicking.
Greetz,
MatchASM
Old 24th February 2011, 08:30 AM   #380
Default hiFace clicking noise issue.
The clicking noise when changing tracks.(and Play)
My hiFace also same problem as Littlesloth.
However I don't hear in one situation.
-OK: Netbook > Foobar > KS_Hiface > coax > DAC(original)
Play:16bit FLAC format file.(Foobar's Vol.max)
-Clicking: Netbook > Foobar > KS_Hiface > coax > DAC(original)
Play:any format file(Foobar's Vol. unless max)
Play:24 bit FLAC format file and 16bit mp3 (Foobar's Vol.max)
I guess that clicking problem in hiFace driver1.0.3 though...
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sandr77
SPDIF on cdrom to SPDIF on Digi Crossover davidallancole Digital Source 0 11th January 2007 03:26 AM
24 bit/192Khz spdif ? ashok Digital Source 30 10th October 2006 03:47 PM
cdrom spdif quality / sound card spdif metebalci Digital Source 0 2nd September 2006 07:16 PM
Is asynch reclock with a can-type oscillator ok? HeadSh0T Digital Source 8 23rd May 2003 07:59 PM
CS8406, CS8416 => 192kHz SPDIF Dave Digital Source 5 11th January 2003 02:20 PM
Page generated in 0.11580 seconds (82.89% PHP - 17.11% MySQL) with 11 queries
