| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#131 | |
#132 |
Most do not. I am tempted to try an ADuM4160. My current solution is to simply isolate the output of the dac chip through a transformer which means that all the PC ground garbage gets through to the USB chip, oversampler and dac - not ideal.
#133 |
Hi Jkeny
Thanks for the great research. I've been looking for a chip to replace the 2707 and this clearly seems to work. Sadly, the implementation appears to be so poor that a complete redesign is probably required. Maybe the manufacturer would be interested in selling bare chips and drivers to diyers. |
#134 | |
#135 | ||
Banned
![]() Quote:
. It is prone to the same PS problems that arise in the Musiland also - switching regulators. But these are easily removed & when clean PS supplied instead the unit really sings so not a bad underlying design really.Don't get too hung up about the galvanic isolation - it still sounds wonderful & I don't know how much better it would be with galvanic isolation. I do know that when I power my laptop from my Linear bench supply the sound improves so maybe that is the area to focus on cleaner, non-switching power supplies to the laptop/PC? If you really want galvanic isolation then go for a Squeezebox Receiver which is what I've done. Only problem is it's limited to 16bit 44/48KHz ( 24/96 when the SB Touch is released ) but I reckon that modded this will sound wonderful also probably better than the HiFace!
#136 |
Banned
Hey Vale, Guido, you really need to try the clock PS mod & report your findings!
#137 |
Hi John,
very nice job you did, congrats. you like the sound now ?as I told you in a previous PM, I replaced onboard regulators on my hiface with ultra low noise linear regs.. tps79318 and tps79333 from TI pinout is the same except one which I lifted and connected to a bypass cap (as per datasheet).. I also replaced two inductors following the previous reg output with two zero ohm smd jumpers. a bit tricky mod due to size. this improved the sound quite significantly I compared mine with stock hiface via spdif (wm8804) .. modded hiface sounds better by a margin my mods so far : external PS, onboard regs, i2s tapping I know you're playing with nanotech batteries for quite some time.. it's time to order some A123 lifepo4.. do you have a source in EU? and yes, next thing I'll try is clock on battery maybe would be a good idea to design a simple battery based PS for every critical low amperage component (DAC, hiface,..) with builtin charger/switcher PS: USB isolation at hi speed (480Mbs) is not available on any known chip (at least to me).. maybe we can focus on I2S isolation using ADUM ?cheers, Vale Last edited by Valeriano; 10th January 2010 at 08:31 PM. |
#138 | |
#139 | |||||
Banned
#140 |
Banned
Sam, I would fall in favour of the SB because it is isolated from PC by ethernet transformer & it has similar building blocks to HiFace a processor that controls Xilinx CPLD feeding I2S to DAC. I'll be removing WiFi & changing the PS, of course, with some other mods.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| sandr77 |
| SPDIF on cdrom to SPDIF on Digi Crossover | davidallancole | Digital Source | 0 | 11th January 2007 03:26 AM |
| 24 bit/192Khz spdif ? | ashok | Digital Source | 30 | 10th October 2006 03:47 PM |
| cdrom spdif quality / sound card spdif | metebalci | Digital Source | 0 | 2nd September 2006 07:16 PM |
| Is asynch reclock with a can-type oscillator ok? | HeadSh0T | Digital Source | 8 | 23rd May 2003 07:59 PM |
| CS8406, CS8416 => 192kHz SPDIF | Dave | Digital Source | 5 | 11th January 2003 02:20 PM |
| Page generated in 0.12121 seconds (88.35% PHP - 11.65% MySQL) with 11 queries |
