Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th November 2009, 08:49 PM   #51
NicMac is offline NicMac  Italy
NicMac's Avatar
Erik,
Just for your info in case you want to use the I2S with the Buffalo....
It won't work as the I2S format output from the CDPRO is not accepted by the Buffalo (maybe do a search at the TP forum for details). You will need some kind of reclocking circuit between the CDPRO and the Buffalo (like the Metronome sold by TP).
Nic
jleaman,
The price is 480US$ with snail mail. Worth the money. Great chassis and very good component quality. Quite a bit of a puzzle assembling it and also some smd solder work involved.
Old 17th November 2009, 08:51 PM   #52
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by NicMac View Post
Erik,
Nic
jleaman,
Id like to buy one, do you have any more pictures ? Smd soldering to me is pretty easy i have all these tools
J'
Old 17th November 2009, 09:14 PM   #53
NicMac's Avatar
J'
I don't have any more photos at the moment. I'm in the (slow) process of assembling the unit. I'm changing quite a deal in the electronics to make it absolute top (mostly PSU mods). There are some pictures in this thread and tons of pictures on the vendors site.
Below find the links I got by mail but you can find a lot of additional pictures as essentially the same chassis/circuit is used in other of their kits:
Here is for the assembly Instructions:
HIFIDIY-KITS*Assembly*Instructions
Aluminum Remote Control Assembly
CD Transport Assembly ----Aluminum Remote Control-HIFIDIY
Chassis Assembly you can check here:
Hifidiy CD Transport Assembly ( I )-HIFIDIY
Old 18th November 2009, 08:08 AM   #54
acidbrain's Avatar
Thanks Nic, Im still thinking too much analog
Old 3rd January 2010, 03:13 AM   #55
jstang is offline jstang  United States
Just upgraded the on power supply board clock to this one... Separate power supply and divider circuit just for the clock. I use the HIFIDIY 16.9mHz crystal. WOW.....
The Power supply board clock was an improvement over the CD-Pro on board clock...but this off board clock/power supply is even better....
1PPM 33.8688 16.9344 MHz Low Jitter TCXO Crystal DAC - eBay (item 300374623889 end time Jan-04-10 09:20:40 PST)
johnk
Old 3rd January 2010, 03:49 AM   #56
Banned
I almost bought one of these kit's however the seller of the company had me emailed 40 times a week and it drove me nuts, GRR!!
Old 9th October 2011, 02:22 PM   #57
acidbrain's Avatar
I have recently upgraded my cd-pro2 chassis :
-used the clock upgrade from the link listed above + extra toroid
-made 2 TP shunt's for 5V & 9V supply
-removed the non used parts from the powerboard.
-only using i2s for data to TP metronome + B2 DAC
It looks simple but it was a lot of work, specially because here is little space.
result : solid, easy, wide, pure sound
your local diy-addict, Erik.
Old 28th January 2012, 01:37 PM   #58
acidbrain's Avatar
Fighting organised hum
Old 29th January 2012, 10:35 AM   #59
Almeg69 is offline Almeg69  United Kingdom
I will be ordering the Mini cd pro kit soon but I would like to use the best possible parts.
Has anyone got the circuit diagram available so I can choose the parts to upgrade ?
Thanks, Alex.
Alex H
Old 29th January 2012, 11:13 AM   #60
acidbrain's Avatar
You get the schematics from the seller, they're in the kit.
Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. Julien_M Swap Meet 5 24th January 2009 11:03 PM
Need CDM-PRO2 transport KIT. DIM Digital Source 16 28th February 2008 10:54 PM
CD-PRO2 transport for sale a333bt Swap Meet 12 5th June 2007 10:12 AM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 08:29 AM
Page generated in 0.10779 seconds (78.94% PHP - 21.06% MySQL) with 11 queries
