Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th October 2009, 05:55 AM   #1
T-Dot is offline T-Dot  Isle of Man
Default input NE5532 replacement
Dear sir,
in my amps, I have NE5532AN as input (right after the rca plug). If I would like to have improvement in sharper imaging, darker background, and less sibilance.
Can I just do direct replacement of the NE5532AN with dual opa211 since both of them are bjt input?
Or do you guys have another opamps that I can replace the NE5532AN directly and get improvement?
Thanks a lot.
Old 8th October 2009, 06:27 AM   #2
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
do you mean OPA2111?
try OPA2134, 10x higher slew rate than 2111.
Old 8th October 2009, 07:19 AM   #3
Mooly's Avatar
If you search these forums you will find lots of threads on this.
http://www.diyaudio.com/forums/searc...earchid=231169
Still favourite for me is the OPA2604... very musical, no stability issues, perfect for replacing the NE5532.
Even the TLO72 would be a surprising improvement musically if the rest of your system is able to highlight the differences. If you don't believe it fit a socket and try some.
In 99.9% of application replacing with a FET input device will not cause any problems.
Old 8th October 2009, 07:36 AM   #4
Banned
Opa2134, opa2604, lm4562, ad8620
Old 8th October 2009, 10:10 AM   #5
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
lm6172, lme47920(4562), njm2114
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua
Old 8th October 2009, 01:08 PM   #6
No Sir Kroto, not 2111
but 2 of the new opa 211 in brown dog adaptor, which the dual version of that is 2211.
I'm not the expert nor do I have the knowledge of changing opamps, but I would like to know if this can be a direct replacement of the ne5532.
And what kind of improvement will I get? I'm using this for my midrange amplifire.
Will it give me blacker background, sharper image, and less sibilance?
Sorry for not having the knowledge, for I'm just gonna try.
if It were needed to be modified in the circuit, I hope it won't be a lot.
Thanks a lot
Old 8th October 2009, 03:47 PM   #7
kroto's Avatar
sorry, I don't know the meaning of sibilance(I don't meet the meaning in the dictionary).
from the datasheet, OPA211 is a very good OpAmp, better than OPA134, this will not cheap. but there is no harm to change NE5532 with OPA2211 (or OPA211 w/ brown dog adaptor).
NE5532 and OPA2211 is pin interchangeable.
high slew rate is more comfortable with high freq' operation(more in detail).
And I think, even TL072 is fairly good for midrange. why dont you try TL072 first? if this doesn't meet your classification, try the other(your OPA211).
Old 8th October 2009, 03:58 PM   #8
Nazar_lv's Avatar
if you have adaptor then the best OP for input stage will be LM318P (especially from TI)
Old 8th October 2009, 04:35 PM   #9
kevinkr's Avatar
The LM4562 would be a natural to consider for replacing a 5532, comparably quiet with improved parameters in all areas.
You should post the schematic of this amplifier before anyone makes a recommendation about changing op-amps. I do not know whether this device is used for buffering/filtering ahead of the actual power amplifier or is actually the error amplifier for the power amplifier itself - in the first instance changing the op-amp should not cause an issue, in the second it very well could cause instability and oscillations.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 8th October 2009, 04:39 PM   #10
I prefer OPA2604 which offer neutral sound.
Current Target - B1 Buffer Preamp / F5 Power Amplifier / Gainclone
Replacement of NE5532 op amps in Meridian speakers azl Chip Amps 10 20th August 2009 08:37 AM
carver pm1.5 input cap replacement Flyingeyepro Solid State 5 7th January 2009 04:55 PM
Input jack replacement Crate BT-350 tonynorie Solid State 6 30th December 2008 11:57 PM
What about NE5532? rhavecilla Chip Amps 12 6th September 2007 03:05 PM
Need Replacement for TC9152 Analog Audio input Selector IC tdownes111 Analog Line Level 3 18th August 2007 06:20 AM
Page generated in 0.64662 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
